| ripper911 |
May 17 2014, 07:45 PM
corde pulsum tangite ![]() ![]() ![]() ![]() Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
What are the chances that I could just tighten the nuts which hold the heat exchangers on without pulling the studs out?
I'm about to set the car up for a morning valve adjustment and figured I'd spray the exhaust nuts with pb blaster and let it soak overnight in hopes of tightening them up. |
| ripper911 |
May 18 2014, 02:30 PM
(IMG:style_emoticons/default/mad.gif) I know what by it's so loud now...
My right side exchanger is only held on by one nut! the muffler end is missing nuts too. You can guess who worked on it last. |
ripper911 killing the lawnmower May 17 2014, 07:45 PM
r_towle
What are the chances that I could just tighten th... May 17 2014, 07:50 PM
kmwvmarip I too recently took off the Heat exchangers and I ... May 17 2014, 08:54 PM
ClayPerrine Replace the copper gaskets that go between the hea... May 17 2014, 10:13 PM
malcolm2
Replace the copper gaskets that go between the he... May 19 2014, 07:04 AM
messix use a 1/4 " drive ratchet.
harder to fuck it... May 18 2014, 02:41 AM
Allan
harder to fuck i... May 18 2014, 05:46 AM
r_towle
:angry: I know what by it's so loud now...... May 18 2014, 02:49 PM
Larmo63 My car is backfiring on deceleration, not to hijac... May 18 2014, 02:37 PM
ripper911 It is jacked up... I don't have any nuts for ... May 18 2014, 02:55 PM
r_towle Just get normal nuts, they work fine May 18 2014, 03:08 PM
ripper911 Done and DONE! Sounds much better! May 18 2014, 05:44 PM
ClayPerrine There is a Mercedes nut used on their exhaust mani... May 18 2014, 09:43 PM
stugray You can get a 8mm thread nut that takes a 12mm wre... May 18 2014, 10:42 PM
malcolm2
You can get a 8mm thread nut that takes a 12mm wr... May 19 2014, 07:07 AM
Larmo63 Are these copper washers available? May 19 2014, 07:07 AM
stugray
I think there is some confusion above.
The coppe... May 19 2014, 07:26 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 04:40 PM |
