> killing the lawnmower
ripper911
post May 17 2014, 07:45 PM
corde pulsum tangite
What are the chances that I could just tighten the nuts which hold the heat exchangers on without pulling the studs out?
I'm about to set the car up for a morning valve adjustment and figured I'd spray the exhaust nuts with pb blaster and let it soak overnight in hopes of tightening them up.
r_towle
post May 18 2014, 03:08 PM
Custom Member
Just get normal nuts, they work fine
ripper911   killing the lawnmower   May 17 2014, 07:45 PM
r_towle   What are the chances that I could just tighten th...   May 17 2014, 07:50 PM
kmwvmarip   I too recently took off the Heat exchangers and I ...   May 17 2014, 08:54 PM
ClayPerrine   Replace the copper gaskets that go between the hea...   May 17 2014, 10:13 PM
malcolm2   Replace the copper gaskets that go between the he...   May 19 2014, 07:04 AM
messix   use a 1/4 " drive ratchet. harder to fuck it...   May 18 2014, 02:41 AM
Allan   use a 1/4 " drive ratchet. harder to fuck i...   May 18 2014, 05:46 AM
ripper911   :angry: I know what by it's so loud now... ...   May 18 2014, 02:30 PM
r_towle   :angry: I know what by it's so loud now......   May 18 2014, 02:49 PM
Larmo63   My car is backfiring on deceleration, not to hijac...   May 18 2014, 02:37 PM
ripper911   It is jacked up... I don't have any nuts for ...   May 18 2014, 02:55 PM
r_towle   Just get normal nuts, they work fine   May 18 2014, 03:08 PM
ripper911   Done and DONE! Sounds much better!   May 18 2014, 05:44 PM
ClayPerrine   There is a Mercedes nut used on their exhaust mani...   May 18 2014, 09:43 PM
stugray   You can get a 8mm thread nut that takes a 12mm wre...   May 18 2014, 10:42 PM
malcolm2   You can get a 8mm thread nut that takes a 12mm wr...   May 19 2014, 07:07 AM
Larmo63   Are these copper washers available?   May 19 2014, 07:07 AM
stugray   I think there is some confusion above. The coppe...   May 19 2014, 07:26 AM
- Lo-Fi Version Time is now: 16th April 2026 - 04:40 PM
