> No start/pertronix
drbill
post May 18 2014, 04:17 PM
Well, I decided to do a major service on this car. 1974 2.0. I've adjusted the valves, replaced the spark plugs NGK BP5ES, gapped to 0.028, replaced the distributor cap, rotor, spark plug wires and installed a Pertronix ignitor.
I've double checked to make sure HT leads attached for proper firing order, battery is charged. I removed #4 plug wire and plug to check for spark: got spark.
Any help? What's a logical sequence to troubleshoot?
Thanks,
Bill (IMG:style_emoticons/default/sad.gif)
drbill
post May 18 2014, 07:08 PM
Thanks, guys. I did double check the connections for the pertronix. Sounds like the consensus is to move the dizzy some and get it started, then can set the timing just right.
drbill   No start/pertronix   May 18 2014, 04:17 PM
Mike Bellis   Try turning the distributor. If you have spark and...   May 18 2014, 05:28 PM
Mblizzard   Did you use the correct spacing between the module...   May 18 2014, 05:56 PM
drbill   I used the spacer that Pertronix provided. 0.030 I...   May 18 2014, 06:10 PM
mskala   I used the spacer that Pertronix provided. 0.030 ...   May 18 2014, 06:17 PM
stugray   You can still do the static timing method with the...   May 18 2014, 06:47 PM
396   Great info I can come back to when the day comes ...   May 18 2014, 06:53 PM
Cap'n Krusty   Great info I can come back to when the day comes...   May 18 2014, 08:01 PM
Rand   Great info I can come back to when the day come...   May 18 2014, 08:09 PM
ClayPerrine   "Upgrade". A BS word, grossly over-and...   May 18 2014, 09:52 PM
drbill   Thanks, guys. I did double check the connections f...   May 18 2014, 07:08 PM
Rand   Spark, fuel, compression, timing......   May 18 2014, 08:11 PM
Dave_Darling   Fuel smell at the tailpipe after cranking the star...   May 18 2014, 08:47 PM
Cap'n Krusty   Something must be wrong with me, Clay. Over the y...   May 18 2014, 10:48 PM
Bartlett 914   Something must be wrong with me, Clay. Over the ...   May 19 2014, 05:50 AM
shuie   Make sure you did not flip the +\- leads on t...   May 19 2014, 05:47 AM
Philip W.   Something must be wrong with me, Clay. Over the...   May 19 2014, 06:34 AM
Java2570   I think the Hot Spark is a Chinese knock off but i...   May 19 2014, 07:25 AM
drbill   I think the Hot Spark is a Chinese knock off but ...   May 19 2014, 10:23 PM
Mblizzard   I think the Hot Spark is a Chinese knock off but...   May 20 2014, 01:01 AM
drbill   Thanks Mike. The HT leads are attached in the righ...   May 20 2014, 05:27 AM
Mblizzard   I am not sure that the 12 degrees of the shaft lin...   May 20 2014, 05:53 AM
drbill   Starting problem solved! I left it alone for a...   May 21 2014, 10:03 PM
The Cabinetmaker   Decel valve has absolutely nothing to do with idle...   May 22 2014, 05:17 AM
r_towle   does the screw that holds down the petronix unit g...   May 22 2014, 06:13 AM
- Lo-Fi Version Time is now: 26th August 2025 - 10:36 PM
