drbill |
Member ![]() ![]() Group: Members Posts: 58 Joined: 12-March 14 From: Fort Mill, SC Member No.: 17,110 Region Association: None ![]() |
Well, I decided to do a major service on this car. 1974 2.0. I've adjusted the valves, replaced the spark plugs NGK BP5ES, gapped to 0.028, replaced the distributor cap, rotor, spark plug wires and installed a Pertronix ignitor.
I've double checked to make sure HT leads attached for proper firing order, battery is charged. I removed #4 plug wire and plug to check for spark: got spark. Any help? What's a logical sequence to troubleshoot? Thanks, Bill (IMG:style_emoticons/default/sad.gif) |
drbill |
Thanks Mike. The HT leads are attached in the right order. The car ran before. I feel like I'm at TDC for #1. The Haynes manual talks about the 12deg for the dizzy shaft... Should be about the same direction as rotor? Anyway, I will double check everything before pulling the dizzy.
Lo-Fi Version | Time is now: 26th August 2025 - 10:36 PM |
