> How to support my car higher off the ground?, Without a lift and without fearing death
PanelBilly
post May 20 2014, 05:05 PM
I've been trying to figure out how I can support the car off the ground so its easier to work on. I was thinking of 30" or so. I've seen some tall jack stands, but they don't have a very wide base. There's no engine in the car, but hat and the tranny are the only part not installed. I was going to borrow a scissor jack, but it requires 230 and i only have 110 in the garage. any ideas? Blocks under the wheels?
jmill
post May 20 2014, 06:01 PM
Green Hornet
QUOTE(PanelBilly @ May 20 2014, 06:05 PM) *
If it's your property and attached to the house, it's very easy to get 220 volts (actually 240) into the garage. Even easier if there is a subpanel in the garage. Might want to hire an electrician buddy if electricity scares you.
http://homerepair.about.com/od/electricalr...40v_breaker.htm
PanelBilly   How to support my car higher off the ground?   May 20 2014, 05:05 PM
wndsnd   Always fear death .... John   May 20 2014, 05:17 PM
914forme   EZ-carlift several of us on the board have them, w...   May 20 2014, 05:32 PM
jhora   EZ-carlift several of us on the board have them, ...   May 21 2014, 02:27 PM
arkitect   I've seen big jack stands on one of the thread...   May 20 2014, 05:35 PM
jmill   I was going to borrow a scissor jack, but it requ...   May 20 2014, 06:01 PM
r_towle   look up JP Stein and his plywood boxes that go und...   May 20 2014, 07:11 PM
McMark   Yup. JPs boxes kinda freak me out, but he used th...   May 20 2014, 07:16 PM
ripper911   http://www.914world.com/bbs2/uploads_offsite/i921....   May 20 2014, 07:18 PM
drive-ability   Harbor Freight has some tall heavy stands. I have ...   May 20 2014, 07:28 PM
914forme   Tons of people use wood. Somewhere I have a coupl...   May 20 2014, 07:49 PM
dlkawashima   no http://www.914world.com/bbs2/uploads_offsite/f...   May 20 2014, 07:49 PM
Garland   Yes Link: [url=http://www.mohawklifts.com/wp/cons...   May 20 2014, 07:57 PM
r_towle   JPs boxes.... Very stable.   May 20 2014, 08:01 PM
malcolm2   but it requires 230 and i only have 110 in the ga...   May 20 2014, 08:11 PM
Steve_R   I made this from some 4X4s and 4 casters. You can ...   May 20 2014, 08:41 PM
bulitt   Depends on your intended use? Looking to raise up ...   May 21 2014, 04:53 AM
rick 918-S   I thought I had a better photo of the stands I use...   May 20 2014, 09:08 PM
Steve   I love my Bendpak MD-6XP scissor lift. It runs on...   May 20 2014, 09:51 PM
stugray   Those plywood boxes are a safe bet if you have som...   May 20 2014, 10:21 PM
carr914   Make some Box Cribs - easy & cheap. Don't ...   May 21 2014, 05:10 AM
MMW   Anyone ever see these in person or use them? http...   May 21 2014, 05:12 AM
bulitt   Those are cool. The price must be a big secret? ...   May 21 2014, 06:14 AM
69telecaster   No matter how you support it, you still have to be...   May 21 2014, 06:50 AM
jmill   After you spend money and time on building that st...   May 21 2014, 07:48 AM
KELTY360   When you finally buy a lift you will slap your for...   May 21 2014, 10:23 AM
Elliot Cannon   Mid rise scissor lift. One of my best investments...   May 21 2014, 12:05 PM
bulitt   :agree: My B in Law just picked a used one up on...   May 21 2014, 02:22 PM
patssle   I spent $1400 on a 2 post lift, $300 on ...   May 21 2014, 02:30 PM
Kansas 914   $50 worth of 2" square tube and a borrow...   May 21 2014, 02:56 PM
Elliot Cannon   I spent $1400 on a 2 post lift, $300 on...   May 24 2014, 11:47 AM
worn   I've been trying to figure out how I can supp...   May 21 2014, 03:01 PM
914forme   I bought mine about 8 years ago. It was when I wa...   May 21 2014, 08:15 PM
JStroud   Look on Craigslist, I found a scissor lift last ye...   May 22 2014, 07:43 AM
Brian_Boss   This has pretty much been covered, but as a summar...   May 22 2014, 08:12 AM
Brian_Boss   Afterthought - To answer the actual question, I al...   May 22 2014, 08:15 AM
Justinp71   Looks like Harbor Freight is a player now too... D...   May 22 2014, 10:04 AM
Amphicar770   Just don't take any short cuts in terms of saf...   May 23 2014, 07:42 PM
stateofidleness   Just don't take any short cuts in terms of sa...   May 24 2014, 11:34 AM
patssle   Two post lifts are great but make sure your con...   May 24 2014, 03:28 PM
Alphaogre   I made this from some 4X4s and 4 casters. You can...   May 23 2014, 07:50 PM
Steve_R   I made this from some 4X4s and 4 casters. You ca...   May 23 2014, 08:29 PM
sixnotfour   :blink:   May 23 2014, 08:55 PM
r_towle   With a stripped tub it took two of us to lift on s...   May 24 2014, 08:28 AM
carr914   RE: How to support my car higher off the ground?   May 24 2014, 10:20 AM
jmalone   what are peoples opinions on storing a vehicle und...   May 24 2014, 01:31 PM
PanelBilly   Lots of interesting ideas. I have limits that I di...   May 24 2014, 05:24 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:47 PM
