| PanelBilly |
May 20 2014, 05:05 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,950 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
I've been trying to figure out how I can support the car off the ground so its easier to work on. I was thinking of 30" or so. I've seen some tall jack stands, but they don't have a very wide base. There's no engine in the car, but hat and the tranny are the only part not installed. I was going to borrow a scissor jack, but it requires 230 and i only have 110 in the garage. any ideas? Blocks under the wheels?
| malcolm2 |
May 20 2014, 08:11 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
| Steve_R |
May 20 2014, 08:41 PM
Member ![]() ![]() Group: Members Posts: 68 Joined: 8-August 12 From: San Diego, CA Member No.: 14,777 Region Association: None |
I made this from some 4X4s and 4 casters.
You can even have Home Depot make all of the cuts and you just screw it together. Attached thumbnail(s) Attached image(s)
| bulitt |
May 21 2014, 04:53 AM
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Depends on your intended use?
Looking to raise up for one time major repair? Looking to raise frequently for service? Need to keep the wheels on? Ok to remove wheels/suspension? Then there is the lifting operation itself. I made this from some 4X4s and 4 casters. You can even have Home Depot make all of the cuts and you just screw it together. (IMG:http://www.914world.com/bbs2/uploads/post-14777-1400639955.jpg) (IMG:style_emoticons/default/smilie_pokal.gif) Lets you move the car around the garage. Make sure you install the large rubber caster wheels (as shown). I used the little ones at first and had ball bearings flying around the garage. (IMG:style_emoticons/default/blink.gif) But can't really replace floor panels with this setup. ![]() If you don't need to remove the tires cool setup. Stands would nest after use and not take up much space for storage. Lets you replace floor panels etc. (IMG:http://www.914world.com/bbs2/uploads/post-43-1400641725_thumb.jpg) |
PanelBilly How to support my car higher off the ground? May 20 2014, 05:05 PM
wndsnd Always fear death ....
John May 20 2014, 05:17 PM
914forme EZ-carlift several of us on the board have them, w... May 20 2014, 05:32 PM
jhora
EZ-carlift several of us on the board have them, ... May 21 2014, 02:27 PM
arkitect I've seen big jack stands on one of the thread... May 20 2014, 05:35 PM
jmill
I was going to borrow a scissor jack, but it requ... May 20 2014, 06:01 PM
r_towle look up JP Stein and his plywood boxes that go und... May 20 2014, 07:11 PM
McMark Yup. JPs boxes kinda freak me out, but he used th... May 20 2014, 07:16 PM
ripper911 http://www.914world.com/bbs2/uploads_offsite/i921.... May 20 2014, 07:18 PM
drive-ability Harbor Freight has some tall heavy stands. I have ... May 20 2014, 07:28 PM
914forme Tons of people use wood. Somewhere I have a coupl... May 20 2014, 07:49 PM
dlkawashima no
http://www.914world.com/bbs2/uploads_offsite/f... May 20 2014, 07:49 PM
Garland Yes
Link:
[url=http://www.mohawklifts.com/wp/cons... May 20 2014, 07:57 PM
r_towle JPs boxes....
Very stable. May 20 2014, 08:01 PM
rick 918-S I thought I had a better photo of the stands I use... May 20 2014, 09:08 PM
Steve I love my Bendpak MD-6XP scissor lift. It runs on... May 20 2014, 09:51 PM
stugray Those plywood boxes are a safe bet if you have som... May 20 2014, 10:21 PM
carr914 Make some Box Cribs - easy & cheap. Don't ... May 21 2014, 05:10 AM
MMW Anyone ever see these in person or use them?
http... May 21 2014, 05:12 AM
bulitt Those are cool. The price must be a big secret? ... May 21 2014, 06:14 AM
69telecaster No matter how you support it, you still have to be... May 21 2014, 06:50 AM
jmill After you spend money and time on building that st... May 21 2014, 07:48 AM
KELTY360 When you finally buy a lift you will slap your for... May 21 2014, 10:23 AM
Elliot Cannon Mid rise scissor lift. One of my best investments... May 21 2014, 12:05 PM
bulitt :agree:
My B in Law just picked a used one up on... May 21 2014, 02:22 PM
patssle I spent $1400 on a 2 post lift, $300 on ... May 21 2014, 02:30 PM
Kansas 914 $50 worth of 2" square tube and a borrow... May 21 2014, 02:56 PM
Elliot Cannon
I spent $1400 on a 2 post lift, $300 on... May 24 2014, 11:47 AM
worn
I've been trying to figure out how I can supp... May 21 2014, 03:01 PM
914forme I bought mine about 8 years ago. It was when I wa... May 21 2014, 08:15 PM
JStroud Look on Craigslist, I found a scissor lift last ye... May 22 2014, 07:43 AM
Brian_Boss This has pretty much been covered, but as a summar... May 22 2014, 08:12 AM
Brian_Boss Afterthought - To answer the actual question, I al... May 22 2014, 08:15 AM
Justinp71 Looks like Harbor Freight is a player now too... D... May 22 2014, 10:04 AM
Amphicar770 Just don't take any short cuts in terms of saf... May 23 2014, 07:42 PM
stateofidleness
Just don't take any short cuts in terms of sa... May 24 2014, 11:34 AM
patssle
Two post lifts are great but make sure your con... May 24 2014, 03:28 PM
Alphaogre
You can... May 23 2014, 07:50 PM
Steve_R
You ca... May 23 2014, 08:29 PM
sixnotfour :blink: May 23 2014, 08:55 PM
r_towle With a stripped tub it took two of us to lift on s... May 24 2014, 08:28 AM
carr914 RE: How to support my car higher off the ground? May 24 2014, 10:20 AM
jmalone what are peoples opinions on storing a vehicle und... May 24 2014, 01:31 PM
PanelBilly Lots of interesting ideas. I have limits that I di... May 24 2014, 05:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:26 AM |
