> First time Valve Adjustment Issues
revhi109
post May 5 2014, 10:56 PM
So I am trying to get my engine back in the car and figured it would make more sense to adjust valves with the engine on the ground. I have never owned a vehicle with a distributor or adjustable valves, So I forgot how this works. I started with TDC on #1 and adjusted valves to .008" which is the smallest gauge I had. turned the crank 90 degrees so the distributor would be firing #4 and adjusted #4's valves and so on. I got to the #2 cylinder and something didnt seem right. the rockers had way too much play and the adjusters wouldnt tighten far enough. I double checked my work on all the cylinders again and they all seemed correct...except the last cylinder. Is it possible that the guy who "rebuilt" my engine put in the wrong rockers or cam? Stumped.
Dave_Darling
post May 23 2014, 08:54 AM
914 Idiot
Whoops! Sorry, I was remembering what a PITA it was on a couple of occasions to get the rods seated that I totally spaced on the symptoms being the opposite...
--DD
revhi109   First time Valve Adjustment Issues   May 5 2014, 10:56 PM
NORD   Check the rockers, are they the same as the others...   May 5 2014, 11:10 PM
stugray   If the cam was the problem you would have the same...   May 5 2014, 11:16 PM
revhi109   Yes Sorry. I meant I turned the crank 180 so that ...   May 5 2014, 11:30 PM
The Cabinetmaker   Did you put the pushrods back in exactly like they...   May 6 2014, 05:06 AM
revhi109   No, I tore the engine apart last fall and mixed th...   May 6 2014, 07:40 AM
Cap'n Krusty   Might want to adjust 'em the way I've outl...   May 6 2014, 07:57 AM
revhi109   I think I found your article you are talking about...   May 6 2014, 08:11 AM
Dave_Darling   Take a quick look at the valve tips. Are they clo...   May 6 2014, 08:40 AM
revhi109   These heads just got back from an aircooled specif...   May 6 2014, 09:39 AM
Cap'n Krusty   These heads just got back from an aircooled speci...   May 6 2014, 09:58 AM
brant   I agree that you need to use the capt'n method...   May 6 2014, 10:45 AM
revhi109   What is stock length? Its a 1.7 case, 1.8 heads, a...   May 6 2014, 11:09 AM
stugray   IMO it is better to understand the basic method to...   May 6 2014, 11:17 AM
Dave_Darling   You can also understand the Cap'n's method...   May 6 2014, 11:44 AM
r_towle   You can also understand the Cap'n's metho...   May 6 2014, 04:54 PM
revhi109   Ok. I think I understand the quick method now. I t...   May 6 2014, 11:54 AM
RogerYellow914   Question, why does it matter if the valves on the ...   May 6 2014, 09:28 PM
Dave_Darling   Look at how the valves open and close, relative to...   May 6 2014, 10:02 PM
RogerYellow914   Both valves are closed. As the crank turns the exh...   May 6 2014, 10:12 PM
Cap'n Krusty   Both valves are closed. As the crank turns the ex...   May 6 2014, 10:23 PM
RogerYellow914   Both valves are closed at the top of the compressi...   May 6 2014, 10:51 PM
Cap'n Krusty   Both valves are closed at the top of the compress...   May 7 2014, 08:10 AM
stugray   That is why I use a notch on my flywheel at 0 de...   May 7 2014, 07:27 AM
Dave_Darling   I use "the book method" as well, and don...   May 7 2014, 08:22 AM
Cap'n Krusty   Someday we should have a race, and we can adjust t...   May 7 2014, 09:23 AM
r_towle   Someday we should have a race, and we can adjust ...   May 7 2014, 12:16 PM
wobbletop   Maybe a simple question... is the back side of a c...   May 7 2014, 12:15 PM
Dave_Darling   Not to mention the Cap'n has done approximatel...   May 7 2014, 12:44 PM
r_towle   Not to mention the Cap'n has done approximate...   May 7 2014, 12:46 PM
revhi109   Ok. So I inspected everything. Made sure I was tru...   May 7 2014, 05:34 PM
brant   weird.... if the push rods were not seated in the...   May 7 2014, 05:48 PM
Dave_Darling   Look at how close the valve tips are to the head w...   May 7 2014, 05:56 PM
revhi109   Correct. Either the rods or the adjuster screws ar...   May 7 2014, 05:59 PM
revhi109   I just installed the heads. Just had them in a mac...   May 7 2014, 06:00 PM
brant   I don't have my long caliper in this town to m...   May 7 2014, 06:02 PM
revhi109   I need to determine if my problem is my pushrods o...   May 7 2014, 10:51 PM
stugray   270-271mm tip to tip The rockers are all the same...   May 7 2014, 10:52 PM
Dave_Darling   Have you actually looked in the rocker box, as I s...   May 8 2014, 10:52 AM
revhi109   I will have to measure the valve height. I just me...   May 8 2014, 11:33 AM
Dave_Darling   I will have to measure the valve height. You don...   May 8 2014, 02:45 PM
stugray   I have two complete sets of used pushrods if you n...   May 8 2014, 12:21 PM
revhi109   I think the valves are fine. I just cleaned, lappe...   May 8 2014, 02:55 PM
revhi109   Finally Put in solid lifters and pushrods. Started...   May 21 2014, 08:31 AM
Cap'n Krusty   If I'm reading the last post correctly, the ga...   May 21 2014, 10:33 AM
bdstone914   Does not make sense that the valves and seats are ...   May 21 2014, 10:57 AM
revhi109   Correct. The engine came with hydraulic lifters an...   May 21 2014, 10:57 AM
revhi109   http://imgur.com/HgsBTHX   May 21 2014, 11:05 AM
bdstone914   http://imgur.com/HgsBTHX Hard to tell but looks...   May 21 2014, 11:41 AM
SLITS   Solid Cam Specs Hydraulic Cam Specs   May 21 2014, 11:15 AM
revhi109   would anything bad happen if I used solid lifters ...   May 21 2014, 02:43 PM
revhi109   http://imgur.com/uYvw66s Stumped. Valves appear t...   May 22 2014, 05:28 PM
Dave_Darling   You can swap rockers around, but I don't remem...   May 22 2014, 09:10 PM
revhi109   I have had the pushrods in and out multiple times ...   May 23 2014, 08:46 AM
Dave_Darling   Whoops! Sorry, I was remembering what a PITA ...   May 23 2014, 08:54 AM
bdstone914   Not sure if this has anything to do with your prob...   May 23 2014, 09:25 AM
stugray   All intake rockers are the same and all exhaust ro...   May 23 2014, 10:03 AM
revhi109   Here is a crazy thought: Is it possible that those...   May 23 2014, 10:14 AM
bdstone914   Here is a crazy thought: Is it possible that thos...   May 23 2014, 11:46 AM
Kirmizi   Here is a crazy thought: Is it possible that tho...   May 23 2014, 11:47 AM
revhi109   Well guys. I finally gave in and brought the engin...   Oct 24 2014, 10:41 AM
stugray   Well guys. I finally gave in and brought the engi...   Oct 24 2014, 10:52 AM
stugray   Just take the suspected "good" set of ro...   May 23 2014, 12:06 PM
Dave_Darling   I believe these are cast pieces, so they are much ...   May 23 2014, 12:11 PM
SLITS   I would like to see images of the lifters he has i...   May 23 2014, 12:52 PM
stugray   He had this problem before I sent him a complete s...   May 23 2014, 02:35 PM
Nine_14   Picture below show all parts involved. Cause o...   May 23 2014, 04:43 PM
revhi109   Well... its not the rockers. I guess Im gunna brin...   May 24 2014, 02:20 PM
revhi109   Yes. I believe it is a bus engine that came with h...   May 24 2014, 02:32 PM
Dave_Darling   You've swapped rockers, and the problem stayed...   May 24 2014, 07:08 PM
brant   How does the lifter look when you pull it out. I...   May 24 2014, 09:49 PM
Java2570   Have you talked to the guy that built this engine ...   May 25 2014, 06:16 AM
stugray   I think he has eliminated everything he can withou...   May 25 2014, 12:02 PM
Bob L.   Do you have a washer between the head and rocker s...   May 25 2014, 12:13 PM
revhi109   There is not a washer underneath the rocker shaft....   May 28 2014, 03:08 PM
Dave_Darling   Could be. One more thing to measure.... --DD   May 28 2014, 03:50 PM
rudedude   Where in minnesota did you find a "pro"?   Oct 24 2014, 12:58 PM
revhi109   Dune Buggy Supply in Hopkins. They've been doi...   Oct 27 2014, 07:14 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:29 PM
