| revhi109 |
May 5 2014, 10:56 PM
Member ![]() ![]() Group: Members Posts: 73 Joined: 20-April 12 From: Minnesota Member No.: 14,404 Region Association: None |
So I am trying to get my engine back in the car and figured it would make more sense to adjust valves with the engine on the ground. I have never owned a vehicle with a distributor or adjustable valves, So I forgot how this works. I started with TDC on #1 and adjusted valves to .008" which is the smallest gauge I had. turned the crank 90 degrees so the distributor would be firing #4 and adjusted #4's valves and so on. I got to the #2 cylinder and something didnt seem right. the rockers had way too much play and the adjusters wouldnt tighten far enough. I double checked my work on all the cylinders again and they all seemed correct...except the last cylinder. Is it possible that the guy who "rebuilt" my engine put in the wrong rockers or cam? Stumped.
| Kirmizi |
May 23 2014, 11:47 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Here is a crazy thought: Is it possible that those 2 rockers got bend if the piston hit the valves? The guy I bought the engine from was selling rebuilt engines from his garage. He had mounds of engine parts. Maybe he used the rockers off a blown engine. Pull off one side and check the problem ones to a non problem set. I would think a push rod would bend first. (IMG:style_emoticons/default/agree.gif) |
revhi109 First time Valve Adjustment Issues May 5 2014, 10:56 PM
NORD Check the rockers, are they the same as the others... May 5 2014, 11:10 PM
stugray If the cam was the problem you would have the same... May 5 2014, 11:16 PM
revhi109 Yes Sorry. I meant I turned the crank 180 so that ... May 5 2014, 11:30 PM
The Cabinetmaker Did you put the pushrods back in exactly like they... May 6 2014, 05:06 AM
revhi109 No, I tore the engine apart last fall and mixed th... May 6 2014, 07:40 AM
Cap'n Krusty Might want to adjust 'em the way I've outl... May 6 2014, 07:57 AM
revhi109 I think I found your article you are talking about... May 6 2014, 08:11 AM
Dave_Darling Take a quick look at the valve tips. Are they clo... May 6 2014, 08:40 AM
revhi109 These heads just got back from an aircooled specif... May 6 2014, 09:39 AM
Cap'n Krusty
These heads just got back from an aircooled speci... May 6 2014, 09:58 AM
brant I agree that you need to use the capt'n method... May 6 2014, 10:45 AM
revhi109 What is stock length? Its a 1.7 case, 1.8 heads, a... May 6 2014, 11:09 AM
stugray IMO it is better to understand the basic method to... May 6 2014, 11:17 AM
Dave_Darling You can also understand the Cap'n's method... May 6 2014, 11:44 AM
r_towle
You can also understand the Cap'n's metho... May 6 2014, 04:54 PM
revhi109 Ok. I think I understand the quick method now. I t... May 6 2014, 11:54 AM
RogerYellow914 Question, why does it matter if the valves on the ... May 6 2014, 09:28 PM
Dave_Darling Look at how the valves open and close, relative to... May 6 2014, 10:02 PM
RogerYellow914 Both valves are closed. As the crank turns the exh... May 6 2014, 10:12 PM
Cap'n Krusty
Both valves are closed. As the crank turns the ex... May 6 2014, 10:23 PM
RogerYellow914 Both valves are closed at the top of the compressi... May 6 2014, 10:51 PM
Cap'n Krusty
Both valves are closed at the top of the compress... May 7 2014, 08:10 AM
stugray
That is why I use a notch on my flywheel at 0 de... May 7 2014, 07:27 AM
Dave_Darling I use "the book method" as well, and don... May 7 2014, 08:22 AM
Cap'n Krusty Someday we should have a race, and we can adjust t... May 7 2014, 09:23 AM
r_towle
Someday we should have a race, and we can adjust ... May 7 2014, 12:16 PM
wobbletop Maybe a simple question... is the back side of a c... May 7 2014, 12:15 PM
Dave_Darling Not to mention the Cap'n has done approximatel... May 7 2014, 12:44 PM
r_towle
Not to mention the Cap'n has done approximate... May 7 2014, 12:46 PM
revhi109 Ok. So I inspected everything. Made sure I was tru... May 7 2014, 05:34 PM
brant weird....
if the push rods were not seated in the... May 7 2014, 05:48 PM
Dave_Darling Look at how close the valve tips are to the head w... May 7 2014, 05:56 PM
revhi109 Correct. Either the rods or the adjuster screws ar... May 7 2014, 05:59 PM
revhi109 I just installed the heads. Just had them in a mac... May 7 2014, 06:00 PM
brant I don't have my long caliper in this town to m... May 7 2014, 06:02 PM
revhi109 I need to determine if my problem is my pushrods o... May 7 2014, 10:51 PM
stugray 270-271mm tip to tip
The rockers are all the same... May 7 2014, 10:52 PM
Dave_Darling Have you actually looked in the rocker box, as I s... May 8 2014, 10:52 AM
revhi109 I will have to measure the valve height. I just me... May 8 2014, 11:33 AM
Dave_Darling
You don... May 8 2014, 02:45 PM
stugray I have two complete sets of used pushrods if you n... May 8 2014, 12:21 PM
revhi109 I think the valves are fine. I just cleaned, lappe... May 8 2014, 02:55 PM
revhi109 Finally Put in solid lifters and pushrods. Started... May 21 2014, 08:31 AM
Cap'n Krusty If I'm reading the last post correctly, the ga... May 21 2014, 10:33 AM
bdstone914 Does not make sense that the valves and seats are ... May 21 2014, 10:57 AM
revhi109 Correct. The engine came with hydraulic lifters an... May 21 2014, 10:57 AM
revhi109 http://imgur.com/HgsBTHX May 21 2014, 11:05 AM
bdstone914
Hard to tell but looks... May 21 2014, 11:41 AM
SLITS Solid Cam Specs
Hydraulic Cam Specs May 21 2014, 11:15 AM
revhi109 would anything bad happen if I used solid lifters ... May 21 2014, 02:43 PM
revhi109 http://imgur.com/uYvw66s
Stumped. Valves appear t... May 22 2014, 05:28 PM
Dave_Darling You can swap rockers around, but I don't remem... May 22 2014, 09:10 PM
revhi109 I have had the pushrods in and out multiple times ... May 23 2014, 08:46 AM
Dave_Darling Whoops! Sorry, I was remembering what a PITA ... May 23 2014, 08:54 AM
bdstone914 Not sure if this has anything to do with your prob... May 23 2014, 09:25 AM
stugray All intake rockers are the same and all exhaust ro... May 23 2014, 10:03 AM
revhi109 Here is a crazy thought: Is it possible that those... May 23 2014, 10:14 AM
bdstone914
Here is a crazy thought: Is it possible that thos... May 23 2014, 11:46 AM
revhi109 Well guys. I finally gave in and brought the engin... Oct 24 2014, 10:41 AM
stugray
Well guys. I finally gave in and brought the engi... Oct 24 2014, 10:52 AM
stugray Just take the suspected "good" set of ro... May 23 2014, 12:06 PM
Dave_Darling I believe these are cast pieces, so they are much ... May 23 2014, 12:11 PM
SLITS I would like to see images of the lifters he has i... May 23 2014, 12:52 PM
stugray He had this problem before I sent him a complete s... May 23 2014, 02:35 PM
Nine_14 Picture below show all parts involved.
Cause o... May 23 2014, 04:43 PM
revhi109 Well... its not the rockers. I guess Im gunna brin... May 24 2014, 02:20 PM
revhi109 Yes. I believe it is a bus engine that came with h... May 24 2014, 02:32 PM
Dave_Darling You've swapped rockers, and the problem stayed... May 24 2014, 07:08 PM
brant How does the lifter look when you pull it out.
I... May 24 2014, 09:49 PM
Java2570 Have you talked to the guy that built this engine ... May 25 2014, 06:16 AM
stugray I think he has eliminated everything he can withou... May 25 2014, 12:02 PM
Bob L. Do you have a washer between the head and rocker s... May 25 2014, 12:13 PM
revhi109 There is not a washer underneath the rocker shaft.... May 28 2014, 03:08 PM
Dave_Darling Could be. One more thing to measure....
--DD May 28 2014, 03:50 PM
rudedude Where in minnesota did you find a "pro"? Oct 24 2014, 12:58 PM
revhi109 Dune Buggy Supply in Hopkins. They've been doi... Oct 27 2014, 07:14 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:01 PM |
