Transaxle issue, Think I have a broken transaxle |
david63 |
May 26 2014, 04:50 PM
Member Group: Members Posts: 96 Joined: 9-August 09 From: Parker Colorado Member No.: 10,653 Region Association: Rocky Mountains |
Looking for input here. Driving the 914-6 (3.0 w/side shift 901) this afternoon in 4th gear when I heard a "noise" or whine and smelled something "warm". Of course I slowed down and it did not occur again at low speeds. I was close to home so I got to the driveway and stopped to look into the problem. At this point the shifter would not move and when I let the clutch out it makes a unpleasant grinding noise. I had the wife steer and I pushed it into the garage.
A little background. The car has always had a little grind going into first and I noticed a little more "grind" than usual today if that means anything. I think it is serious because of the sound and odor thing. Possibly just a shifter thing? Probably not? Planning on pulling it and having it rebuilt most likely? Ideas? |
Mike Bellis |
May 26 2014, 09:29 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
The clutch cable may be stretching. Before you go too far try to tighten the adjustment nut. If it works better, buy a new cable.
Lo-Fi Version | Time is now: 23rd May 2024 - 07:41 AM |
