Running Really Hot on the Track, I don't necessarily mean fast |
ww914 |
May 10 2014, 03:51 PM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
Yesterday at Buttonwillow for our DE, the temperature was not all that hot, but I could only get in 2 laps at race speed before my CHT gauge started hollering at me. Here are the maximum values from yesterday:
Cyl #1 384 degrees Cyl #2 357 degrees Cyl #3 433 degrees Cyl #4 402 degrees I have the alarm set at 400 degrees, so each time it reached that temp, I backed off and let it cool down and finished each session with just a Sunday drive. Here's what I have: My engine is a 2270 built by Original Customs 2 40 DLRAs: 150 main jets 180 air correction jets 34 venturis 9164.2 emulsion tubes 75 idle jets 50 pump jets Both carbs are accurately sync'd and the a/f gauge shows between 13 - 14 all through the progression to WOT The timing is set to about 30 degrees I am running a stock cooling system with the thermostat and flaps working properly. I pulled engine tin to look for obstructions. None. I am running a Sebtrab 8 x 10 oil cooler but my temps are over 220 when pushing it hard. No fans. I am not sure where to go from here: alternate cooling, larger oil cooler, fans? Any suggestions would be appreciated. |
ChrisFoley |
May 27 2014, 10:21 AM
I am Tangerine Racing Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Warren,
would you like to be the guinea pig for my new oil pressure relief device? I have a prototype ready for testing, just need a car with oil pressure gauge for monitoring. |
Jetsetsurfshop |
May 27 2014, 11:17 AM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Warren, would you like to be the guinea pig for my new oil pressure relief device? I have a prototype ready for testing, just need a car with oil pressure gauge for monitoring. Whats the intent of this device? Is it something you can swap out without draining the oil? I stay up at night worrying about oil temps, will this help me sleep? Shane |
ChrisFoley |
May 27 2014, 12:24 PM
Warren, would you like to be the guinea pig for my new oil pressure relief device? I have a prototype ready for testing, just need a car with oil pressure gauge for monitoring. Whats the intent of this device? Is it something you can swap out without draining the oil? I stay up at night worrying about oil temps, will this help me sleep? Shane This will eliminate the circuit in the crankcase which bypasses the stock cooler under high oil pressure conditions. It can be swapped out without draining the oil. I believe this will help a lot of us sleep better. This is the first prototype, and is ready to be installed/tested. We'll have a couple more ready tomorrow with a couple of minor changes. The weld build-up on the side orients the tube so the high pressure relief holes line up with slots in the case. The plan for production is a screw which retains the spring and has an exposed head which fits in the slot. |
Lo-Fi Version | Time is now: 11th June 2024 - 09:59 AM |
