Running Really Hot on the Track, I don't necessarily mean fast |
ww914 |
May 10 2014, 03:51 PM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
Yesterday at Buttonwillow for our DE, the temperature was not all that hot, but I could only get in 2 laps at race speed before my CHT gauge started hollering at me. Here are the maximum values from yesterday:
Cyl #1 384 degrees Cyl #2 357 degrees Cyl #3 433 degrees Cyl #4 402 degrees I have the alarm set at 400 degrees, so each time it reached that temp, I backed off and let it cool down and finished each session with just a Sunday drive. Here's what I have: My engine is a 2270 built by Original Customs 2 40 DLRAs: 150 main jets 180 air correction jets 34 venturis 9164.2 emulsion tubes 75 idle jets 50 pump jets Both carbs are accurately sync'd and the a/f gauge shows between 13 - 14 all through the progression to WOT The timing is set to about 30 degrees I am running a stock cooling system with the thermostat and flaps working properly. I pulled engine tin to look for obstructions. None. I am running a Sebtrab 8 x 10 oil cooler but my temps are over 220 when pushing it hard. No fans. I am not sure where to go from here: alternate cooling, larger oil cooler, fans? Any suggestions would be appreciated. |
PotterPorsche |
May 28 2014, 10:17 PM
Member Group: Members Posts: 295 Joined: 10-November 13 From: Hayward CA Member No.: 16,628 Region Association: None |
Have you tried 180 air 160 mains or possible 190 airs 155 mains. Interested in the WOT numbers Also what venturis? 32mm i assume
ww914 |
May 29 2014, 08:43 AM
Have you tried 180 air 160 mains or possible 190 airs 155 mains. Interested in the WOT numbers Also what venturis? 32mm i assume I am running 160 mains with 180 A/C which got my WOT at redline a/f readings to around 12.0, through 34 venturis, but the cyl temps were still too high, especially #3. The oil temps were also running too high 230 to 250. I am almost ready to re-install the engine with the few things I found wrong and with Tangerine Racing remote oil cooler kit. We'll see what happens. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:54 PM |
