First Engine Start Questions, First Engine Start |
Highland |
Apr 17 2014, 09:39 AM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I'm getting close (a relative term) to starting my motor for the first time. It is a stock 2.0 with Raby 9590 valve train. I know the easiest thing to do is put it in the car and start, but I have a running engine in the car now and I suspect I'll have to fix something after a try to start it. Here are my questions:
1) I have a spare transmission with starter. Can I start the engine without a clutch on the flywheel? 2) Can I start the engine without the alternator installed? 3) Without a charging system, can I use a car battery to power the coil and D-Jet for the break-in period (assuming I get that far) or will the battery die before then? 4) If I can't use a car battery to power the ignition and D-Jet, how big a power supply will I need? |
stugray |
Apr 17 2014, 10:19 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Here is some help:
1- Dont install the pushrods (cranking to prime with pushrods installed will wipe away the cam lube you put on the cam & lifters) 2 - remove the sparkplugs 3 - install a mechanical oil pressure gauge if you have one. 4 - do NOT fill the oil filter with oil before installation 5 - crank the engine until oil pressure peaks then keep cranking for as long as you are comfortable to get oil through the whole system. (Dont overheat the starter - ~10 seconds at a time, then cool off) 6 - check oil and top off if required 7 - reinstall pushrods & set valve lash (with Jakes pushrods, cold lash is zero) 8 - reinstall spark plugs 9 - proceed with engine first startup & follow Jakes cam break-in instructions |
kkid |
May 29 2014, 03:04 PM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
Here is some help: 1- Dont install the pushrods (cranking to prime with pushrods installed will wipe away the cam lube you put on the cam & lifters) 2 - remove the sparkplugs 3 - install a mechanical oil pressure gauge if you have one. 4 - do NOT fill the oil filter with oil before installation 5 - crank the engine until oil pressure peaks then keep cranking for as long as you are comfortable to get oil through the whole system. (Dont overheat the starter - ~10 seconds at a time, then cool off) 6 - check oil and top off if required 7 - reinstall pushrods & set valve lash (with Jakes pushrods, cold lash is zero) 8 - reinstall spark plugs 9 - proceed with engine first startup & follow Jakes cam break-in instructions Why NOT for #4? |
Lo-Fi Version | Time is now: 12th June 2024 - 08:50 AM |
