Oil pressure relief, oil cooler, and accusump interaction |
Seabird |
May 19 2014, 08:53 AM
Member Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States |
Good morning everyone. I am in the process of upgrading my oil system. This is on my dedicated track 914. The upgrades include remote oil cooler, accusump, and CB Maxi oil pump.
In my research for installing the accusump it seems like there are two places that are recommended, in the cooler return line with a check valve and direct to the block. I did not want to use the sandwich plate adapter so I opted for the block option. Simpler with less seals to fail. As I looked into the workings of the type IV oil system I found a potential problem with both these locations; the oil relief valve on the front of the engine. VW used this valve to bypass the cooler when the oil is thick. But this also means the cooler is bypassed when the oil pressure is high. Does the use of an oil accumulator negate the oil cooler system by maintaining oil pressure? While on the straights the pump could potentially make 50-60 psi of oil pressure. (the 30mm pump that was in the engine produces those pressures much of a 20 min session) At those oil pressures the cooler will be bypassed based on what I know of the relief valve (bypassing cooler at 60psi, partially open at 35 psi, and sealed at 12psi). The accusump will also build up to that pressure. When I go to brakes and the revs drop the accusump will start pushing back and keep the pressure up till the differential is corrected. If I am back on to the next straight in that time then the pump starts building the pressure again. Options: 1. Am I making a mountain out of a mole hill? Leave it alone. 2. Plug that relief valve so it stays closed and let the oil cooler thermostat bypass the oil when its cold. This is a pre 76 case so there is the secondary relief valve by cylinder 1. Might be able just to invert the piston so the bypass grove is below the bypass passages. 3. There is also the high pressure pistons sold by pelican parts and others. Does this just shift the bypass window to a higher pressure range? I would love to hear people's thoughts on this. Miguel |
Seabird |
May 31 2014, 07:37 PM
No puller fan. It's a race car, it should not have to idle too much once it gets up to temp.
Some racer friends came over last night and we got a bunch of the car buttoned up. Today after work another friend came over with his scales and we corner weighted the car. 2166 with my full figure in the drivers seat. 50.2% cross 51.8% rear. Pretty happy with those numbers. That's puts me pretty close, weight wise to where I need to be for HSR. Went through the whole accusump priming routine. Filled up the oil sump. Added extra for the cooler and fird it up. I let it idle for 10 mins and it did not break 150. With some higher revs I was able to get the gauge to approach 170. Did that for a little while and gave up on getting it to heat up. The cooler was warm to the touch and the gauge was reading, works for me. I still have a few details to sort out but the bulk of the work is done. Will be ready for next Sunday in no time (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 4th June 2024 - 03:21 PM |
