idle on a 2056 with 9590 cam |
jmargush |
Dec 12 2013, 03:50 PM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I am having trouble getting my new 2056 with a 9590 cam to idle. When I start it is idles around 500rpm or lower and I can't speed it up with the by pass screw.
I am running L-jet injection I hear a hissing sound when the engine is idling but I cannot find a vacuum leak, plenum couplers are new and all other hoses are in good shape. I can't find the hissing with a mechanics stethoscope so I was going to try to find a leak with propane but it has been too cold to work on it lately. The idle does seem to get a little better after it has warmed up a bit I think, it has been several weeks since I have had it out. One question I had is does the new cam require any change to the mixture? if so how do I go about adjusting the mixture? Thanks in advance for any input |
ChrisFoley |
Jun 1 2014, 10:45 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Have you read up on how to tune L-jet?
Are you familiar with the bypass screw on the air flow meter? Have you tried adjusting it? Its doubtful that drilling a hole in the throttle plate will improve the function of your system. The idle is so low because there isn't enough fuel for the amount of air getting in the engine. |
Lo-Fi Version | Time is now: 1st June 2024 - 08:47 PM |
