Fuel Injection problems, strange |
86motoman |
Aug 12 2004, 06:06 PM
Member Group: Members Posts: 200 Joined: 13-May 04 From: Walla Walla, WA Member No.: 2,064 |
I have a fuel injection issue. I bought the car not running. It has djet (?) Fuel Injection. It hasn't run for about five years, though they said it was running when it went in the garage.
It does start and run, but strangely it seems to run after I unplug the fuel pump relay. The fuel pump relay is mickey moused. Meaning it has a hot wire coming from the coil and wrapped around one of the relay posts and then plugged in. Without that wire the fuel pump does not turn on. With the fuel pump running the car does not want to start. After unplugging the fuel pump relay it starts good and runs good for a few seconds. I know little about fuel injection but am willing to learn. I really want this to work for me. I have a multi-meter. What should I check first? |
mike_the_man |
Aug 13 2004, 09:08 AM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
Check Brad Anders site. It could be that the Manifold Pressure Sensor (MPS) is not working. Thats the grenade looking thing. If you have a vaccum pump, pull a vaccum on it and if it leaks, its defective. A leaking MPS can cause the car to run really rich. Also, it could be a bad Cylinder Head Temp sensor (CHT). All of this is explained on Brads site, with trouble shooting procedures.
Good luck, and keep asking question. |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:36 AM |
