> Starting Issues, Subaru Conversion
malaga_red75
post Jun 4 2014, 02:05 PM
'74 2.5L N/A Subie
My car is a '74 with a 2.5L JDM Subaru motor and stock 914 tranny.
Background on the issue: (sorry for length.. want to give the full picture)
I used the original 914 starter motor when I finished the conversion which failed within a few months. (This was expected as the compression in the subie is much much higher)
I then switched to the 911 starter motor which worked for ~2 years no problem. I took a trip down the coast to LA and ended up driving through a pretty serious rain storm (this could be coincidence or a possible cause of the problem) - this is when my problems started.
The starter motor felt like it no longer had enough 'juice' to turn over the subie motor (I would get maybe 1 or 2 cranks at a time). Thinking it was just a failed started motor, I switched to the 'Hi-Torque' starter motor. This worked for a few weeks then failed and had the same symptoms I experienced with the 911 starter motor. I decided to switch back to a new 911 starter motor and same thing... worked for a few weeks then failed.
The weird part is, is that if the car has sat for a bit (more than a few days), it generally starts right up - or if i use jumper cables (i.e. 2 batteries) with another car. But, if i drive it, then park, then try to start it again, it most likely wont start.
I've tried different batteries, different starter motors, replaced possible faulty cables and nothing seems to have changed.
At this point, I'm really lost on solving this issue. Hoping you guys can help.
Thanks in advance,
peter
malaga_red75
post Jun 4 2014, 03:50 PM
'74 2.5L N/A Subie
It is a Bosch relay. Just to confirm my test... on the input terminal on my relay I get 12.3v (coming from the battery)... On the output terminal in the 'start' position, I get ~10v. Shouldn't this be 12.3v?
My understanding of a relay is that once you activate the relay with the ignition switch, it just connects the two other terminals.. if one side has 12.3v, shouldn't there be 12.3v coming through to the other terminal?
- Lo-Fi Version Time is now: 16th July 2025 - 12:19 PM
