> Money shift., Help me figure this out.
ottox914
post Jun 4 2014, 10:09 PM
The glory that once was.
A friend of mine, whom I would trust with my life or my wife, was taking the 914 for a little test beating with me the other day. At about 7k rpm and 15 psi he money shifted me from 3rd to 2nd. He WAS very quick to throw the clutch back in, but...
I now need a new fan belt, as the OEM one was thrown and is slightly mangled at present. More concerning, is the noise it makes now. It isn't the 1 in 4 cycle "thump, thump" of a rod bearing. I can pull plug wires and rev it up and the sound remains. Its more of a tic-tic-tic-tic-tic thing. Due to the speed of the tic tic tic and that it goes up and down with rpm, I'm thinking valves. Not that i really want to think that.
Any other thoughts or trouble shooting to be tried that anyone else can think of?
I'm thinking to start with compression test, move to leakdown, and submit some of the oil for testing of metallic ick. I can do the compression test and send in the oil, but I don't have the tools for the leakdow.
r_towle
post Jun 4 2014, 11:17 PM
Custom Member
QUOTE(ottox914 @ Jun 5 2014, 12:09 AM) *
Use a compression tester threaded hose hooked up to a 125 psi compressor in each cylinder.
Listen with a hose to your ear and the intake, exhaust and oil filler holes for sound.....you can hear it right through a muffler pipe if it's leaking and you can hear well enough...
ottox914
post Jun 5 2014, 06:41 AM
I can probably rig something up. I thought the "right" way to do this was with gauges and such, to measure the rate of leakdown. I get how this process would at least identify leaking at the valve, and which valve it might be. Don't I need to have the motor at TDC with both valves closed, and them find some way to "lock" it in that position, so the pressure of the air does not push the piston down and rotate everything, opening a valve? Any BTDT to set this process up and get it right? I'd hate to do it wrong, think I have a bunch of bad valves, rip it all apart and find a simple fix rather than the valve thing.
Should I be able to visually inspect the head for other damages, or if I can see the bent valve just replace it and be good enough. I put a bunch of $$$ and Len put a bunch of time into those heads... they were perfect.
ottox914   Money shift.   Jun 4 2014, 10:09 PM
Mike Bellis   Never let anyone drive a turbo 914. :(   Jun 4 2014, 10:16 PM
rick 918-S   Wow! Sorry to here. Maybe it dropped a seat. U...   Jun 4 2014, 10:55 PM
ottox914   Wow! Sorry to here. Maybe it dropped a seat. ...   Jun 5 2014, 06:47 AM
'73-914kid   :stromberg: I'm sorry to hear that someone ...   Jun 4 2014, 11:14 PM
messix   bent valve   Jun 4 2014, 11:14 PM
r_towle   A friend of mine, whom I would trust with my life...   Jun 4 2014, 11:17 PM
ottox914   I can probably rig something up. I thought the ...   Jun 5 2014, 06:41 AM
76-914   I can probably rig something up. I thought the...   Jun 5 2014, 08:09 AM
Jake Raby   There's nothing good about "zinging...   Jun 5 2014, 09:19 AM
horizontally-opposed   If it was zinged at 7K that hard it HAS to come ...   Sep 18 2014, 03:42 PM
SirAndy   Money shift I added a constant reminder to my cu...   Jun 5 2014, 11:38 AM
Mike Bellis   Money shift I added a constant reminder to my c...   Jun 6 2014, 09:25 AM
SirAndy   I think you're missing a couple $$.....   Jun 6 2014, 11:08 AM
horizontally-opposed   I think you're missing a couple $$....   Sep 18 2014, 03:40 PM
gms   Money shift I added a constant reminder to my c...   Sep 14 2014, 07:16 PM
infraredcalvin   My buddy has several race cars with a crude versio...   Jun 5 2014, 08:16 PM
ottox914   Going to check out the car tomorrow. Still don...   Jun 7 2014, 02:33 PM
messix   for some reason I thought you had a six.... if it...   Jun 7 2014, 03:14 PM
'73-914kid   Figure out which valves are loose by pulling the v...   Jun 7 2014, 03:32 PM
ottox914   Onward with the auto-topsy. Heads will be on the ...   Sep 14 2014, 07:06 PM
Cuda911   ^^^ Me too! Would love that tach face.   Sep 14 2014, 10:25 PM
ottox914   Heads are headed to the Head Master, Len. We...   Sep 17 2014, 01:50 PM
Jake Raby   I expect you'll find that all the bearings are...   Sep 18 2014, 01:34 PM
- Lo-Fi Version Time is now: 11th July 2025 - 05:26 AM
