Brake fittings / size / DIN ? |
drive-ability |
Jun 5 2014, 07:14 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
To start with I have this but the adaptors are incorrect. They are for a standard flair fitting. I need the German style / double bubble ? What's it called ???
Second I'm using a Wilwood pedal box W/2 brake master cylinders and the brakes are Boxster front part number 996351426. There's some shots below, I don't know what size bore masters to use. Anyone have any thoughts ? (IMG:http://www.914world.com/bbs2/uploads_offsite/image.fourwheeler.com-3782-1402017286.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i987.photobucket.com-3782-1402017286.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i987.photobucket.com-3782-1402017286.3.jpg) |
Dave_Darling |
Jun 5 2014, 10:07 PM
The whole point of dual master cylinders is so you do not have to run a proportioning valve. One M/C feeds the rear, the other feeds the front. You change the linkage between the pedal and the M/Cs to change the brake bias. No prop valve (or pressure limiting valve) needed.
--DD |
Lo-Fi Version | Time is now: 9th June 2024 - 06:33 PM |
