> AAR and High Idle
lsintampa
post May 22 2014, 02:41 PM
75 2.0 FI w/backdated exhaust
Motor recently rebuilt.
Injectors cleaned / all are very good. New points, condenser, blah blah. Most everything is new .... except:
FI parts were all just laying about for IDK, maybe 10 - 15 years or so.
Car DID have A/C - but not any more.
The shop that did the motor rebuild did a great job, but they didn't sign up to muck with the FI system. They did a great job on the rebuild and did as much as needed to get the car running, but left the FI tweaking for me.
Which is fine - assuming I can tackle it myself, or (if not) farm it back out. I asked for the option.
That said, I notice that the hose that goes to the IN port of the AAR (the larger of the two hoses), gets sucked closed when the car is running. By that I mean the suction is so great it basically collapses the hose (pinching it).
I haven't had the time (wife just got out of some surgery yesterday) to play with it, but I'll pull that hose and replace it with something a bit more sturdy.
I don't know what effect that would have on the idle - if any.
Idle is a bit high, in the neighborhood of 1100 (more or less at times). Depends if I just am sitting or came to a rolling stop, etc. But mostly let's call it 1100. The car is very responsive and runs strongly. No issues there.
I don't have access to any high end diag equipment, so most of what I can do would be try this - see if it helps. I do have vacuum gauge, timing light, basic stuff.
I'm wondering if (since the car did have A/C), somewhere in the past if some adjustments were made to the FI system to account for the extra strain the compressor and pulley added to the motor? (resulting now in a high idle) I think they (the shop) did all they could without mucking with components. Adjusting throttle cable, air valve, etc.
So, what effect on the idle would the AAR intake hose collapsing on itself have?
Should the suction be that strong to cause the hose to collapse? (I think the hose is one that came from the AA FI hose kit).
I think it makes sense to first address the AAR hose situation before moving onto the idle issue, just don't know if they are related or not??
Thanks,
Len
lsintampa
post Jun 6 2014, 01:59 PM
75 2.0 FI, cat delete, exhaust backdated
I stand corrected. I thought the idle leveled off, but the car was HOT when the hunting range was tiny. But ....
Idle does hunt, most of the time.
At cold start the hunting is between 900 and maybe 1200, then at midrange hunting is near stall to maybe 1000, then when hot the idle is high and the hunt range is small - like from 1200 - 1300.
Once the motor is a full temp, the idle remains high with very slight hunting - as mentioned above.
All the V-lines are NEW. The FI components are original - as far as I can tell.
I think the AAR is working because once the motor warms up, the idle does drop.
I've not bypassed the AAR as yet. Still trying to figure out the idle issue.
A question about the air box... I don't know what the small tubes are for that seem to run through it. They are about 1/4 inch in diam and I thought they were for some sort of support or something. Anyway, should they be tight? By tight I mean that I can sort of wiggle them about / turn them.
I copied a photo from another post for reference. The tube I'm talking about is the small one in the photo with the water streaming down from it (under the big TB opening).
I seem to recall mine were loose, but I'd think if they are supposed to be "sealed" that my issue would be bigger than what it is.
- Lo-Fi Version Time is now: 11th July 2025 - 05:14 PM
