> Weird issue with shifting, Solved!
914itis
post Jun 6 2014, 12:02 PM
My shift linkage is well sync , no grinding at all and smooth shifting. All my bushings are new, shift rod cone screws are all tight in there .
Here is the issue.
If I am driving the car a bit aggressive, sometimes I would loose 4th and 5th, if I quickly move the shifter in neutral left and right (jiggle)a few times, they come back.
My guest is clutch cable adjustment or shifter itself.
Any ideas ?
toolguy
post Jun 6 2014, 03:22 PM
Does the trouble happen when you're going straight or when in a turn. .
If only when turning hard, then maybe body flex. .
My experience is bad clutch adjust is usually mostly prevalent when going into 1st at a standstill. .
You may want to try changing the shift shaft joint one spline over in the tunnel at thre joint and see if that makes an improvement. . . and the 1st / rev plane still works OK
post Jun 6 2014, 03:46 PM
Resident German
QUOTE(toolguy @ Jun 6 2014, 02:22 PM) *
^^^ That ...
If it only happens in corners, your body is flexing to the point where the shift rod gets in a bind. BTDT.
- Lo-Fi Version Time is now: 16th June 2024 - 08:29 PM
