AF meter how do i go about reading this. |
jmargush |
May 28 2014, 07:44 PM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I borrowed a AF meter from a friend and was wondering what is the best process for reading and setting the mixture.
Can I take readings at idle and hold the throttle at 3k and take another reading or do i need to drive it with it under load? based on readings which adjustment do I move first static or dynamic? |
jmargush |
May 31 2014, 05:42 PM
Drilled hole in the TB and had noticeable improvement on idle.
got numbers as follows for AF ratio Accel. - 12.4 - 13.7 WOT - 12.1 - 12.7 Cruise - 12.6 - 13 Coast - 12.9 - 13.3 The cruise isn't as lean as what I have seen is desired. So which adjustment do I go about to bring that in line? Static or dynamic ? I have not moved the mixture screw on the outside of the meter yet it is set 4 1/2 turn open. Idle numbers are still all over the map cause now it won't come back down off of idle Unless you load the engine and pull it down that way, so it idles around 1200-1900 rpms At around 1200 I am seeing 14 |
jim_hoyland |
Jun 6 2014, 08:22 PM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Drilled hole in the TB and had noticeable improvement on idle. got numbers as follows for AF ratio Accel. - 12.4 - 13.7 WOT - 12.1 - 12.7 Cruise - 12.6 - 13 Coast - 12.9 - 13.3 The cruise isn't as lean as what I have seen is desired. So which adjustment do I go about to bring that in line? Static or dynamic ? I have not moved the mixture screw on the outside of the meter yet it is set 4 1/2 turn open. Idle numbers are still all over the map cause now it won't come back down off of idle Unless you load the engine and pull it down that way, so it idles around 1200-1900 rpms At around 1200 I am seeing 14 The throttle body of the L Jet has 2 air connections that originally went to the distributor. In my car both have been plugged, a Mallory Unilite was installed. Could one of the air inlets be comparable to drilling the hole ? |
Lo-Fi Version | Time is now: 9th June 2024 - 10:55 AM |
