Fuel Injection problems, strange |
86motoman |
Aug 12 2004, 06:06 PM
Member Group: Members Posts: 200 Joined: 13-May 04 From: Walla Walla, WA Member No.: 2,064 |
I have a fuel injection issue. I bought the car not running. It has djet (?) Fuel Injection. It hasn't run for about five years, though they said it was running when it went in the garage.
It does start and run, but strangely it seems to run after I unplug the fuel pump relay. The fuel pump relay is mickey moused. Meaning it has a hot wire coming from the coil and wrapped around one of the relay posts and then plugged in. Without that wire the fuel pump does not turn on. With the fuel pump running the car does not want to start. After unplugging the fuel pump relay it starts good and runs good for a few seconds. I know little about fuel injection but am willing to learn. I really want this to work for me. I have a multi-meter. What should I check first? |
john rogers |
Aug 13 2004, 09:01 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
If you jumper pins 30 to 87 on the relay or run 12 volts to the relay as you have, the pump will run when ever the key is on. Is this good or bad? Depends since it goes against the factory deign it is not good and if you leave the key on you could have fuel leak past an injector(s). The only advantage to this is to have the ability to know the pump is actually working before cranking so the car will start. Some say you need to do this to be able to push start a D-Jet 914 but not true. Good luck
Lo-Fi Version | Time is now: 10th June 2024 - 10:16 AM |
