proper class for a 2056 |
jmargush |
Jun 16 2014, 07:54 PM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I was reading the parade classification to determine the proper class for my car in PCA autox
I have a 2056 raised spindles and modified camber up front So as I read it would be IO2 4cyl 2000cc - 2699cc but the minimum weight is supposed to be 2500lbs. I don't think my car weighs that much. do I need to carry ballast? |
jmargush |
Jun 16 2014, 08:44 PM
Found some 2014 rules I see some things have changed on the improved classes
but it still doesn't say you are allowed a other than non stock cam in improved Production says you must use stock but improved doesn't make mention of cams. |
Borderline |
Jun 16 2014, 10:05 PM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
Found some 2014 rules I see some things have changed on the improved classes but it still doesn't say you are allowed a other than non stock cam in improved Production says you must use stock but improved doesn't make mention of cams. A 2.5.6.1 (j) camshafts: any camshaft may be used. FWIW |
Lo-Fi Version | Time is now: 28th May 2024 - 06:10 PM |
