> Engine swap changing coils, What size / type coil?
jsaum
post Jun 23 2014, 11:53 AM
I'm in the middle of an engine swap and am so close to getting my car on the road I can barely stand it! I'm putting a 1.8 motor from a 75 into my 72 and found that the size of the coil that normally mounts to the engine tin is different from the one that has the bracket that mounts on the blower housing. Does anyone know the correct part number or coil to use for that mounting bracket?
Thanks,
Jsaum
Dave_Darling
post Jun 23 2014, 04:34 PM
914 Idiot
Look up on the engine tin. You'll find two holes with weld-nuts. Those hold the original coil bracket onto the tin, at least on earlier cars. (I think some of the 1.8s had the coil where you show it? But I'm not sure.)
The bracket that comes with the Bosch blue coil does not work with those two holes, unless you are willing to use and trust some very large fender washers. The new bracket is shorter than the old and the holes don't line up very well at all.
I used a piece of bicycle inner tube wrapped around the coil to get it to fit the old bracket. It has worked fine for many years. I have heard stories of duct tape adhesive softening over the years and allowing the coil to move around.
--DD
ThePaintedMan
post Jun 23 2014, 04:43 PM
QUOTE(Dave_Darling @ Jun 23 2014, 06:34 PM) *
--DD
(IMG:style_emoticons/default/agree.gif) DON'T use duct-tape, unless it's just to get home. The heat from the engine will melt the adhesive quickly. Also, the neoprene I used originally had lost some of it's shape and the coil eventually worked its way loose... and promptly fell into the fan area. Luckily when I got to work I noticed what had happened. Ate about .5 inches out of the coil, but it still functioned.
I've since used a split section of hose to use as a rubber buffer between the bracket and coil... and of course, replaced the coil for good measure. (IMG:style_emoticons/default/headbang.gif)
Cap'n Krusty
post Jun 23 2014, 05:18 PM
Cap'n Krusty
QUOTE(ThePaintedMan @ Jun 23 2014, 03:43 PM) *
--DD
Musta been el cheapo duct tape. I ran my T4 in the bus for 10 years with a duct tape wrapped coil. (Things connected to me have a way of being exceedingly cool, so heat might not have been a factor ...........) I'm not saying it's the best way, but its "a" way. The hose sounds better, but one would have to be VERY careful about the thickness.
The Cap'n
jsaum   Engine swap changing coils   Jun 23 2014, 11:53 AM
Cap'n Krusty   They take the same coil. The most common replacem...   Jun 23 2014, 12:32 PM
jsaum   Maybe the bracket is bent or would there be a stud...   Jun 23 2014, 12:53 PM
worn   Maybe the bracket is bent or would there be a stu...   Jun 24 2014, 11:56 AM
Dave_Darling   Look up on the engine tin. You'll find two ho...   Jun 23 2014, 04:34 PM
ThePaintedMan   I used a piece of bicycle inner tube wrapped arou...   Jun 23 2014, 04:43 PM
Cap'n Krusty   I used a piece of bicycle inner tube wrapped aro...   Jun 23 2014, 05:18 PM
jsaum   Look up on the engine tin. You'll find two h...   Jun 24 2014, 10:29 AM
Cap'n Krusty   Might want to give us a picture of the coil and th...   Jun 24 2014, 10:35 AM
sean_v8_914   i do not recommend "on the tins" mountin...   Jun 24 2014, 12:15 PM
Drums66   i do not recommend "on the tins" mounti...   Jun 24 2014, 01:25 PM
worn   i do not recommend "on the tins" mounti...   Jun 24 2014, 02:33 PM
jsaum   OK I got this picture on Google for a VW type 4 so...   Jun 24 2014, 04:42 PM
jsaum   OK I got this picture on Google for a VW type 4 s...   Jun 24 2014, 04:43 PM
Dave_Darling   With the extra holes on that, I'm betting that...   Jun 24 2014, 05:08 PM
Cap'n Krusty   With the extra holes on that, I'm betting tha...   Jun 24 2014, 06:14 PM
zambezi   Yup, stock bracket. You can just barely make out ...   Jun 24 2014, 08:39 PM
jsaum   OK I think I figured it out probably the bracket w...   Jun 27 2014, 02:12 PM
Cap'n Krusty   Way to go. I would put a nut and washer between t...   Jun 27 2014, 03:30 PM
jsaum   Yes I did put a nut there so it shouldn't back...   Jun 28 2014, 10:31 AM
- Lo-Fi Version Time is now: 11th July 2025 - 04:00 AM
