| Dave_Darling |
Jun 22 2014, 10:21 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Here are the questions from the 914 section of the 2014 Parade tech quiz. Several of the questions appear to have been written by "real" 914 folks; see for instance Q 53 answer a. (IMG:style_emoticons/default/smile.gif)
There are a few answers that are debatable, according to your point of view as well. The questions I got wrong were: 55, 67, 69. I actually got 67 right, but the official answer was wrong. (That question was successfully protested and thrown out.) - - - - - - - - - 51) The 914-4 is known internally (at the VW factory) as the a) peoples’ car; b) Karmann; c) VW-Porsche; d) VW Type 47. 52) Pop-up headlights were used on the 914 a) in order to comply with U.S. lighting-height law; b) to give sleeker appearance when not in use; c) as an attempt to keep them cleaner; d) to develop the concept for the future 924. 53) What is the approximate fuel pressure at the injectors of the D-Jetronic system? a) Enough for a leak b) 75 psi c) 10 psi d) 30 psi 54) Both the 914-4 and 914-6 used a hand throttle. a) True b) False 55) A 914-6 was used as a pace car for the 1971 Daytona 500. a) True b) False 56) For the 1974 model year American market the base engine was a 1.8 liter with a) D-Jetronic fuel injection; b) L-Jetronic fuel injection; c) K-Jetronic fuel injection; d) Motronic fuel injection. 57) The 914 used the same 901 gear box as the 911 but turned end for end. Because of the __________. a) the ring gear had to be mounted opposite of the 911 location. b) it required a reverse rotation throwout bearing c) all the gears had to be flipped end for end d) the engine rotation was reversed 58) The front suspension on the 914 is a) unequal length A arm; b) coil spring concentric with shock; c) torsion bars with McPherson struts and lower wishbones. d) torsion bar concentric with shock; 59) The 914 1.8 liter camshaft is driven by _________ a) timing chain b) toothed belt c) gears d) pure luck 60) The 1.7 and 1.8 liter engines do not share the same crankshaft. a) True b) False 61) The windshield wiper switch on a 1970 914-4 was located a) The switch was made by Lucas and never worked, so it doesn’t matter where it was. b) on the steering column. c) on the dash d) on the center console 62) The brake lights are activated by a hydraulic switch. a) True b) False 63) A shortcoming of the early 914’s was the shift linkage. The improved version came in 1973. a) True b) False 64) What tool is needed to remove the tail light lenses on the 914? a) Fingers b) Phillips screwdriver c) Straight tip screwdriver d) 10mm wrench 65) The engine of the 914/6 was the same as used in the 1970 911T. a) True b) False 66) All 914 bodies were built by a) Reutter b) Porsche c) Karmann d) VW 67) The production 914-4 and 914-6 cars for the U.S. market had the “Porsche” crest on the hood. a) True b) False 68) In 1973 the method for wheel centering was changed from _______. a) bolt centric to hub centric b) hub centric to bolt centric c) orbitally to closed cone method d) variable to definite 69) The firing order of the 914/6 engine is ______. a) 18436572 b) 146325 c) 164235 d) 162435 70) The hoses on 1973 914 2.0 fuel injection unit are color coded. The brown hoses are related to the ____________. a) deceleration valve b) windscreen washer c) distributor d) EGR valve 71) The vapor lock problem on 914-4’s was alleviated when Porsche moved the fuel pump to the front of the car. a) True b) False 72) The 914-6 option package M471 included ______________. a) flared fenders. b) flared rocker panels. c) flared front valance. d) all of the above 73) For 1970 and 71 leather trim was only available on six-cylinder models. a) True b) False 74) The problems with the shaft and bushings which support the brake and clutch pedal assembly could cause _______________. a) dragging brakes b) overheated brakes c) inconsistent pedal height d) all of the above 75) On a 914 1.8 there are two electric boxes attached to the underside of the battery tray. One is the J40 double relay and the other is a resistor package that provides reduced voltage from the battery to the __________. a) interior light b) tachometer c) brake lights d) fuel injectors |
| ConeDodger |
Jun 24 2014, 03:40 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,426 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
Class: Q06M
Region 914 1 107 5 0592A Darling David Loma Prieta (38, 23) 2 102 4 0291A Blyholder Andrew Golden Gate (33, 23) 3 98 4 0274A Rudawsky George Chicago (35, 21) 4 93 4 0858A Spreen Carey Maverick (39, 18) 5 84 5 0297A Kust Paul Oregon (33, 17) 6 83 4 0822A Howard Travis Maverick (26, 19) 7 83 2 0092A Koozmin Mike Loma Prieta (32, 17) 8 82 4 0446A Checel Lester Northern Ohio (31, 17) 9 77 4 0061A Biddle Robert Arizona So, I didn't see an overall winner. Were the tests all model specific? |
Dave_Darling 2014 Parade Tech Quiz, 914 section Jun 22 2014, 10:21 PM
ConeDodger Pure luck crankshaft drive... What a novel idea th... Jun 22 2014, 11:51 PM
barefoot where are answers posted ?? Jun 23 2014, 06:55 AM
Dave_Darling
They aren't. ... Jun 23 2014, 11:05 AM
GeorgeRud They actually managed to have some printing/collat... Jun 23 2014, 08:34 AM
SLITS d,a,d,b,a,b,d,c,c,b,c,b,a,a,a,c,b,a,d,a,a,d,a,c,d.... Jun 23 2014, 11:26 AM
Dave_Darling d,a,d,b,a,b,a,c,c,b,c,b,a,a,b,c,b,a,d,a,a,d,a,d,d
... Jun 24 2014, 11:44 AM
SLITS
d,a,d,b,a,b,a,c,c,b,c,b,a,a,b,c,b,a,d,a,a,d,a,d,d... Jun 24 2014, 02:43 PM
Jeff Bowlsby Those are tough questions Dave...Congrats to you... Jun 23 2014, 01:19 PM
Dave_Darling Answers here:
1) The 91... Jun 24 2014, 11:41 AM
Cap'n Krusty I coulda been the winner!
The Cap'n Jun 24 2014, 02:19 PM
Dave_Darling It's a lot easier here than sitting in a room ... Jun 24 2014, 02:34 PM
The Cabinetmaker I only missed #69 cause I had no idea. Never worke... Jun 24 2014, 02:56 PM
Jeff Bowlsby I think we should start a thread and generate our ... Jun 24 2014, 03:03 PM
Dave_Darling So, I didn't see an overall winner. Were the t... Jun 24 2014, 05:16 PM
Krieger E. All of the above. Jun 24 2014, 04:00 PM
Krieger Good job Dave :first: Jun 24 2014, 04:01 PM
dlkawashima I guess I don't understand how the scoring goe... Jun 24 2014, 06:53 PM
theleschyouknow
I guess I don't understand how the scoring go... Jun 24 2014, 07:09 PM
theleschyouknow
I guess I don't understand how the scoring g... Jun 24 2014, 07:13 PM
Jamie
[quote name='theleschyouknow' post='2053991' date... Jun 24 2014, 08:56 PM
Dave_Darling
I guess I don't understand how the scoring go... Jun 24 2014, 09:35 PM
theleschyouknow
I guess I don't understand how the scoring g... Jun 24 2014, 11:04 PM
Manny Alban Yup, I'm a long time 914 owner (73 2.0) and de... Jun 24 2014, 09:22 PM
theleschyouknow
Yup, I'm a long time 914 owner (73 2.0) and d... Jun 24 2014, 10:56 PM
Dave_Darling Oops. Yeah, that's 137 for my overall total.
... Jun 25 2014, 08:44 AM
Tom Dave,
Question about #61, 1970 914 windshield w... Jun 25 2014, 11:59 AM
Cap'n Krusty The "brown" hoses in question 70 were ac... Jun 27 2014, 09:20 AM
Dave_Darling IIRC, there were brown hoses and there were red ho... Jun 27 2014, 12:29 PM
Cap'n Krusty IIRC, and it's been a while, they arrived at t... Jun 27 2014, 12:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 12:15 PM |
