> License plate and dash lights on with key on, but lheadlight switch in the off position
HalfMoon
post Jun 23 2014, 07:50 PM
I started my car tonight and noticed despite the headlight switch being fully in the off position, my dash lights are on and my license plate light is .
Odd. Never saw that before. Headlight switch I imagine....
Thoughts?
David
Addedum-and saw what I thought was a wisp of smoke come from under my dash at the windshield....perhaps my imagination?
ovilla
post Jun 26 2014, 12:53 AM
HalfMoon, I have the exact same issue as you and am currently waiting on delivery of a "new to me" switch. Anyway, I'm going to open up my old one (the later fat switch with extra terminal from my 75 2.0) and will let you know what I discover.
I've also been having an issue with my passenger light not coming up (but going down fine), so I think my switch finally melted on me. Also, right now, with the car on and volts at 12+, turning on my headlights makes my drivers side light go up and down continuously - as if it had a low voltage condition. My passenger side light still doesn't pop up on its on.
HalfMoon   License plate and dash lights on with key on   Jun 23 2014, 07:50 PM
dangrouche   Here is the bird board repair of the switch; I...   Jun 23 2014, 08:11 PM
HalfMoon   Here is the bird board repair of the switch; I...   Jun 23 2014, 08:41 PM
HalfMoon   Hmmm.... odd question. Is the wiper switch and the...   Jun 25 2014, 03:49 PM
Dave_Darling   The two switches do work with each other, in that ...   Jun 25 2014, 03:54 PM
HalfMoon   The two switches do work with each other, in that...   Jun 25 2014, 03:56 PM
Dave_Darling   Wiring diagrams: http://www.pelicanparts.com/914/...   Jun 25 2014, 05:55 PM
HalfMoon   Wiring diagrams: http://www.pelicanparts.com/914...   Jun 25 2014, 08:06 PM
HalfMoon   Interesting. http://www.914world.com/bbs2/index.ph...   Jun 25 2014, 08:56 PM
GeorgeRud   I may be way out there, but doesn't the light ...   Jun 25 2014, 09:31 PM
HalfMoon   I may be way out there, but doesn't the light...   Jun 25 2014, 09:54 PM
HalfMoon   Ok. So I've fouund (in my manual of all place,...   Jun 25 2014, 09:47 PM
john77   I have a 73 that also came with mixed up relays. O...   Jun 26 2014, 12:50 AM
HalfMoon   ...and then the three black ones are for fogs, ho...   Jun 26 2014, 11:27 AM
ovilla   HalfMoon, I have the exact same issue as you and a...   Jun 26 2014, 12:53 AM
Dave_Darling   Sorry, I just noticed a typo! The third of th...   Jun 26 2014, 08:45 AM
HalfMoon   Sorry, I just noticed a typo! The third of t...   Jun 26 2014, 11:24 AM
HalfMoon   Somewhat academic at this point as I've repl;a...   Jun 26 2014, 01:14 PM
HalfMoon   The mystery relay Addedum-relay number 002479-01...   Jun 26 2014, 01:22 PM
rmital   [quote name='HalfMoon' post='2054661...   Sep 19 2020, 08:30 AM
TheVintagePassion   Hello at all, I'm Carmine Borraccino From Ital...   Oct 8 2020, 01:35 AM
rmital   Hello at all, I'm Carmine Borraccino From Ita...   Oct 8 2020, 12:06 PM
Dave_Darling   Much clearer pics, thanks! D has a red, a red...   Jun 26 2014, 04:19 PM
HalfMoon   Much clearer pics, thanks! D has a red, a re...   Jun 26 2014, 06:28 PM
dadaDaveed   [quote name='Dave_Darling' post='2054726' date='J...   Jun 26 2014, 09:18 PM
HalfMoon   [quote name='Dave_Darling' post='2054726' date='...   Jun 26 2014, 09:44 PM
HalfMoon   Process of elimination. I swapped in a spare (and ...   Jun 26 2014, 07:50 PM
Jeff Bowlsby   Here are some testing diagrams for the dash switch...   Jun 26 2014, 09:26 PM
HalfMoon   Here are some testing diagrams for the dash switc...   Jun 26 2014, 09:48 PM
HalfMoon   Today I thought I would pull the headlight dimmer ...   Jun 28 2014, 12:31 PM
dadaDaveed   Today I thought I would pull the headlight dimmer...   Jun 28 2014, 12:59 PM
HalfMoon   Today I thought I would pull the headlight dimme...   Jun 28 2014, 09:11 PM
dadaDaveed   I just pulled my fuse panel to take a look. 56 ...   Jun 28 2014, 09:31 PM
dadaDaveed   Honestly, I don't know if swapping 56a and 56b...   Jun 28 2014, 09:36 PM
HalfMoon   Honestly, I don't know if swapping 56a and 56...   Jun 28 2014, 09:45 PM
HalfMoon   Made the dimmer switch tonight but no love. Fuses ...   Jun 29 2014, 09:27 PM
Dave_Darling   Look for places (especially lights) where wires co...   Jun 29 2014, 10:18 PM
Tom   You need to find out why fuse #8 is blowing, Accor...   Jun 30 2014, 06:31 AM
HalfMoon   You need to find out why fuse #8 is blowing, Acco...   Jun 30 2014, 08:08 PM
Tom   "0" ohms from the load side of the fuse ...   Jul 1 2014, 12:22 AM
HalfMoon   "0" ohms from the load side of the fuse...   Jul 1 2014, 09:25 AM
Tom   David, The "load" side of a fuse i...   Jul 1 2014, 11:37 AM
HalfMoon   David, The "load" side of a fuse ...   Jul 1 2014, 12:52 PM
HalfMoon   Working on an assumption that each component wire ...   Jul 1 2014, 01:28 PM
Tom   David, First of all, you need to separate all...   Jul 1 2014, 06:19 PM
HalfMoon   David, First of all, you need to separate al...   Jul 1 2014, 07:19 PM
HalfMoon   Did more testing today per Tom's recommendatio...   Jul 2 2014, 02:43 PM
Tom   Sounds like a bad wiper motor to me. A good one sh...   Jul 2 2014, 08:36 PM
HalfMoon   Sounds like a bad wiper motor to me. A good one s...   Jul 3 2014, 12:13 PM
HalfMoon   Interesting afternoon out in the garage with Littl...   Jul 3 2014, 07:27 PM
Tom   David, Glad to see you now know what the proble...   Jul 4 2014, 12:28 AM
HalfMoon   David, Glad to see you now know what the probl...   Jul 4 2014, 02:01 PM
Tom   Remember that 53a goes to both your wiper motor an...   Jul 4 2014, 03:00 PM
Tom   David, I was reading back thru some of your ...   Jul 5 2014, 01:32 PM
HalfMoon   David, I was reading back thru some of your...   Jul 5 2014, 01:56 PM
HalfMoon   Rats. I hooked up my spare to the cars harness (an...   Jul 5 2014, 01:58 PM
Tom   David, Well, that clears up the readings! T...   Jul 5 2014, 06:21 PM
HalfMoon   David, Well, that clears up the readings! ...   Jul 6 2014, 01:35 PM
Tom   David, Does your blower motor work? The blower ...   Jul 6 2014, 02:02 PM
HalfMoon   David, Does your blower motor work? The blower...   Jul 6 2014, 02:27 PM
Tom   David, Are those wires properly terminated to k...   Jul 6 2014, 03:19 PM
HalfMoon   David, Are those wires properly terminated to ...   Jul 6 2014, 09:11 PM
HalfMoon   Actually..... Friend Valy has suggested disconnect...   Jul 6 2014, 11:40 PM
HalfMoon   Got out in the shop for a bit today and performed ...   Jul 7 2014, 03:09 PM
HalfMoon   Hmpf. Pretty confused today. I did a side by side ...   Jul 7 2014, 07:58 PM
HalfMoon   Swapped out the new 924 switch from my 1973 for n...   Jul 7 2014, 10:38 PM
Tom   Progress! That's good. Not take voltage m...   Jul 8 2014, 04:04 AM
HalfMoon   Progress! That's good. Not take voltage ...   Jul 8 2014, 10:34 AM
HalfMoon   Found something interesting. A continuity problem ...   Jul 8 2014, 06:17 PM
HalfMoon   Well duh me. On the learning curve. Slot 5 of the...   Jul 9 2014, 06:15 PM
HalfMoon   Sigh. Well it has been a long long road but my wip...   Aug 4 2014, 10:06 PM
76-914   Sigh. Well it has been a long long road but my wi...   Aug 5 2014, 08:11 AM
HalfMoon   Oh, btw, if anyone would be interested in verifyin...   Aug 4 2014, 10:08 PM
dangrouche   after reading your thread, I thought about offerin...   Aug 4 2014, 11:18 PM
HalfMoon   after reading your thread, I thought about offeri...   Aug 4 2014, 11:28 PM
rhodyguy   what's the story with the grey exposed wire in...   Aug 5 2014, 01:28 PM
HalfMoon   what's the story with the grey exposed wire i...   Aug 5 2014, 02:46 PM
- Lo-Fi Version Time is now: 7th July 2025 - 12:34 AM
