| dax1969 |
Jun 27 2014, 06:30 AM
Member ![]() ![]() Group: Members Posts: 400 Joined: 10-March 14 From: belgium Member No.: 17,103 Region Association: None
Good afternoon,
My shop just called that the small oil leak I have on my 73 2.0 is situated down on the oiltubes (or do you call it push rod tubes ?) and that he needs the pull the engine to fix the issue. For my knowledge (I'm no mechanic) is the oil leak usually caused by bad/dried out seals or can the tubes have an issue themselves. In short, is it best to replace all seals or also all tubes ? thks yr advice note : can I it drive for a while with this small leak and fix the issue in winter or does it need urgent attention ? Car is in the shop for 5 weeks now to fix the rustissue on my aft bottomfloor and realy want to drive it for a couple of weeks or till winter falls in. krgds Dax |
| 914itis |
Jun 27 2014, 06:54 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Yes they are caused by dry cracked seals and can be replace without dropping the engine.
I would take care of it sooner than later , the oil from the push rods are dripping on the heat exchangers and may cause fire. |
dax1969 oil leak - need advice Jun 27 2014, 06:30 AM
cary A couple thoughts. First, it really depends on how... Jun 27 2014, 06:54 AM
dax1969
A couple thoughts. First, it really depends on ho... Jun 27 2014, 07:01 AM
stugray Dax,
Inspect the pushrod tubes and verify that th... Jun 27 2014, 07:13 AM
dax1969
Dax,
Inspect the pushrod tubes and verify that t... Jun 27 2014, 07:30 AM
dax1969
Holy sh*t... scary...
I've read as much as ... Jun 27 2014, 07:14 AM
cary It's easier with the engine out. But the R... Jun 27 2014, 07:19 AM
luskesq AA can probably get you the seals but if you do a ... Jun 27 2014, 08:18 AM
bdstone914 Auto Atlanta has few fans on this site due to poor... Jun 27 2014, 08:23 AM
Racer Chris Mia at Auto Atlanta is from Belgium.
In fact, she ... Jun 27 2014, 08:42 AM
dax1969
thks guys... just bought new Viton seals @ PP
... Jun 27 2014, 08:55 AM
Cap'n Krusty A professional mechanic should easily be able to r... Jun 27 2014, 09:09 AM
Dave_Darling The key is that you only have to pull the tubes ha... Jun 27 2014, 12:30 PM
Cap'n Krusty If you want to really get them clean, they can be ... Jun 27 2014, 12:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 02:16 AM |
