> oil leak - need advice
dax1969
post Jun 27 2014, 06:30 AM
Good afternoon,
My shop just called that the small oil leak I have on my 73 2.0 is situated down on the oiltubes (or do you call it push rod tubes ?) and that he needs the pull the engine to fix the issue.
For my knowledge (I'm no mechanic) is the oil leak usually caused by bad/dried out seals or can the tubes have an issue themselves.
In short, is it best to replace all seals or also all tubes ?
thks yr advice
note : can I it drive for a while with this small leak and fix the issue in winter or does it need urgent attention ? Car is in the shop for 5 weeks now to fix the rustissue on my aft bottomfloor and realy want to drive it for a couple of weeks or till winter falls in.
krgds
Dax
dax1969
post Jun 27 2014, 07:14 AM
the oil from the push rods are dripping on the heat exchangers and may cause fire.
Holy sh*t... scary...
I've read as much as possible already and one says it can be done without removing the engine and the other ones says (and my shop) you will have to pull the engine.
Note : my shop is an aircooled VW shop but he "says" he has experience on T4 engines and 914's as well. Unfortunately the 914 is very rare here and real 914 specialists are non existant or tucked away in their own garages.
Mmmh, time to take a decision
thks
Dax
- Lo-Fi Version Time is now: 15th April 2026 - 02:16 AM
