> oil leak - need advice
dax1969
post Jun 27 2014, 06:30 AM
Good afternoon,
My shop just called that the small oil leak I have on my 73 2.0 is situated down on the oiltubes (or do you call it push rod tubes ?) and that he needs the pull the engine to fix the issue.
For my knowledge (I'm no mechanic) is the oil leak usually caused by bad/dried out seals or can the tubes have an issue themselves.
In short, is it best to replace all seals or also all tubes ?
thks yr advice
note : can I it drive for a while with this small leak and fix the issue in winter or does it need urgent attention ? Car is in the shop for 5 weeks now to fix the rustissue on my aft bottomfloor and realy want to drive it for a couple of weeks or till winter falls in.
krgds
Dax
Cap'n Krusty
post Jun 27 2014, 12:46 PM
Cap'n Krusty
If you want to really get them clean, they can be removed from the engine with the engine in the car, as can the pushrods. It takes some fiddling, but they DO come out.
The Cap'n
- Lo-Fi Version Time is now: 15th April 2026 - 02:17 AM
