-6 Throttle Cable Connection, Not using the transmission pivot |
patssle |
Jun 29 2014, 10:44 AM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
The /4 cable is more than long enough not to need the extra hardware to pivot on the transmission and save some money. Just need to fabricate a bracket and mount it off one of the couple spots available.
My /4 cable does not have a threaded end to attach a ball socket. Has anybody else worked with this and somehow either put a ball socket on a non-threaded cable or used something on the bar linkage that allows for cable movement? |
GeorgeRud |
Jun 29 2014, 11:31 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Perhaps you could braze a ball end onto the end of the cable or try to drill, tap, and install a small Allen head setscrew to hold the connector onto the cable. Then you'd have to have a bracket that can adjust the hold down at the cable shroud.
When it's all said and done, I wonder if mimicking the factory setup may not be easier and cheaper in the long run. |
Lo-Fi Version | Time is now: 7th June 2024 - 07:57 AM |
