| pgollender |
Jun 29 2014, 11:47 AM
Member ![]() ![]() Group: Members Posts: 201 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
I'm confused by a front window seal that maybe should go back into my '70. The window has a front metal track with small Derlin rollers, but it looks like there there should be a rubber seal that attaches to the track to prevent water entry. I know the front triangle window has a (almost) water tight seal, but it is stationery. My '73 has a front window seal that sets into the track, but no Derlin roller set up. What's the deal ?
is there a conversion seal that works on the early models 914'ers, or am I stuck with a surface that will constantly drip into the bottom of my door? Attached image(s)
| Mikey914 |
Jun 29 2014, 11:58 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,786 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
If your glass has the rollers you can't use the fuzzy as it goes where the rollers are. The late mechanism has no rollers in the track, so the fuzzy helps guide it in the track.
You could convert the window over to the late, but it also requires longer horizontal aluminum tracks as the end caps are different. The late are shorter. As long as the window mechanisms work, no real need to change out, unless the lack of fuzzy bothers you. |
pgollender 1970 vs 1973 front window seals Jun 29 2014, 11:47 AM
OU8AVW "unless the lack of fuzzy bothers you."
... Jun 30 2014, 11:31 AM![]() ![]() |
Lo-Fi Version | Time is now: 21st November 2026 - 11:25 AM |
