> Converting to 2.0 Heat Exchangers from 1.7 Heat Exchangers, The definitive parts list
FlatSix
post Jun 30 2014, 02:50 AM
English Member
I have a 1.7 engine. I'm planning on changing my heat exchangers to 2.0 stainless heat exchangers. I've had a stab at creating a list of the parts that I need to source to do this below. Have I missed anything?
2x 2.0 Heat Exchangers (I have)
1x 2.0 Exhaust (I have)
1x 2.0 Exhaust Hanger Bracket (I have)
4x Gaskets H/E to Cylinder Head - I see part nos. are different for 1.7 and 2.0, which do I need?
8x Nuts H/E to Cylinder Head - what size?
2x Gaskets H/E to Exhaust
6x Nuts and Bolts H/E to Exhaust - what size?
Does the existing warm air elbows etc. carry over to the new installation or am I in for more expense?
How much of a PITA is it to remove old rusty H/E's? some of the nuts look to be well hidden. Do I need a special tool or will a regular socket set do?
Thanks in advance.
Dave_Darling
post Jun 30 2014, 08:46 AM
914 Idiot
For the exhaust nuts, use exhaust nuts. They are fairly specialized parts, with a copper coating and a self-locking feature. Pelican and many other outlets carry them.
The exchanger-to-muffler fasteners are regular M8 nuts and bolts. They don't need to be very long, but it's not super critical if they are a bit longer than needed.
--DD
Cap'n Krusty
post Jun 30 2014, 09:10 AM
Cap'n Krusty
QUOTE(Dave_Darling @ Jun 30 2014, 07:46 AM) *
--DD
BAD advice, Dave! Air cooled Porsches and VWs DO NOT use locking nuts for the exhaust systems. The nuts you are pushing for Pelican were first introduced for water cooled VWs and BMWs. Porsche used conventional nuts with Helicoil inserts on the earlier1.7/1.8 and late 2.0 engines, and similarly inserted thick flanged nuts for the earlier 2.0 engines. Neither were of the locking variety. There is a torque spec for the conventional nuts, and there is NO WAY that spec could be properly achieved with a self locking nut. Remember, just because you can buy something doesn't mean you should either buy or use it. Look at all the "009" distributors out there ..................
The Cap'n
- Lo-Fi Version Time is now: 14th April 2026 - 06:15 AM
