> FRUSTRATED! Electrical issues!
SKL1
post Jun 26 2014, 09:04 AM
Here comes the rant- the electrical issues are driving me nuts.
Other than putting the car back together (and everything worked when I dissassembled it) I put in a JWest fuse panel. When first bringing the car back to life with a battery, many things are NOT working. Headlight motors have power as I can raise them by turning the little knobs until the lights go thru a cycle, but they don't go up with the light switch. Also, no headlights, just parking lights. At first, emergency flashers and turn signals worked, now the flasher just makes a horrible buzzing sound, and the signals flash at about double speed.
Also, bench test shows starter is fine, but when in car, nothing happens when turning igntion switch. Also, shorting the starter with screw driver doesn't activate it.
Oh, and the light in the top of left gauge continues to flash whenever ignition is on- I think that's warning for brakes- E brake is off, and wiring to master cylinder is connected, though there is no blade connector on it for the ground...
And NO fog lights...
Have NEW ground strap from tranny to body and battery to body...
I have NO idea even where to START!!
I've been working on these cars for over 40 years, and HATE electrical issues!!!
SKL1
post Jun 30 2014, 05:59 PM
Definitely using proper dual filament front bulbs. Funny because when I first put the battery in the lights and flasher worked, then a front bulb burned out and when I replaced it, all this started.
Cleaned all the grounds in the trunk by the headlight motors, etc. Have 12V to headlight motor relays, but still nothing when pulling out headlight switch.
Starting to check power to all the fuses. Boy that is fun after a two level cervical fusion... this was a hell of a lot easier when I first got the car 43 years ago!!!!
SKL1   FRUSTRATED! Electrical issues!   Jun 26 2014, 09:04 AM
bandjoey   How bout pull all the fuses and put them back one ...   Jun 26 2014, 09:08 AM
stugray   loosen the JWest fuse panel and let it hang. If t...   Jun 26 2014, 09:21 AM
JWest   As mentioned in email, the starter circuit does no...   Jun 26 2014, 11:19 AM
SKL1   I doubt it is the panel itself (not trying to bla...   Jun 26 2014, 11:30 AM
damesandhotrods   Electrical problems are usually at the connections...   Jun 26 2014, 11:38 AM
stugray   Just relaying info from other threads: "Th...   Jun 26 2014, 12:39 PM
Spoke   Here comes the rant- the electrical issues are dr...   Jun 26 2014, 01:59 PM
Tom   I didn't see if this was your 71 or 73. If it ...   Jun 26 2014, 02:22 PM
damesandhotrods   A good start would be to print out a copy of the s...   Jun 26 2014, 04:44 PM
cwpeden   And the Current Flow Diagram helps too. Choose f...   Jun 26 2014, 05:17 PM
toolguy   Make sure all your grounds are good is a starting ...   Jun 26 2014, 06:07 PM
SKL1   thanks for the suggestions guys- all good. I...   Jun 26 2014, 07:12 PM
swooshdave   have an old Penske voltmeter from the '70...   Jun 29 2014, 11:49 PM
dadaDaveed   I went through similar troubleshooting pains recen...   Jun 26 2014, 09:33 PM
SKL1   Well... I decided to start with the starter circui...   Jun 29 2014, 07:34 PM
Dave_Darling   Remove that one bulb. Chances are you put the wro...   Jun 29 2014, 10:23 PM
damesandhotrods   You’re going to need 12 volts going from the bat...   Jun 30 2014, 01:52 AM
SKL1   Definitely using proper dual filament front bulbs....   Jun 30 2014, 05:59 PM
- Lo-Fi Version Time is now: 12th March 2026 - 09:18 AM
