HalfMoon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region ![]() |
I started my car tonight and noticed despite the headlight switch being fully in the off position, my dash lights are on and my license plate light is .
Odd. Never saw that before. Headlight switch I imagine.... Thoughts? David Addedum-and saw what I thought was a wisp of smoke come from under my dash at the windshield....perhaps my imagination? |
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
You need to find out why fuse #8 is blowing, According to the prints from Pelican, fuse #8 feeds the following: Fresh air blower and switch that controls the speeds, cigarette lighter, and wiper motor. With the power disconnected, use a multimeter to measure the ohmic value between ground and the load side of fuse #8. It should be very low, ( like 0 ohms - grounded), that is why the fuse is blowing. Now you need to see which wire is giving the low reading. If there are multiple spade terminals, remove them one at a time to find which one is grounded. One of them is bad, it is just a matter of finding the bad one and then fixing what is wrong.
Tom EDIT: Quick check - pull the cig lighter out and see if there is corrosion inside. With lighter out does the reading on the load side of fuse #8 get higher in ohms? Tom |
HalfMoon |
You need to find out why fuse #8 is blowing, According to the prints from Pelican, fuse #8 feeds the following: Fresh air blower and switch that controls the speeds, cigarette lighter, and wiper motor. With the power disconnected, use a multimeter to measure the ohmic value between ground and the load side of fuse #8. It should be very low, ( like 0 ohms - grounded), that is why the fuse is blowing. Now you need to see which wire is giving the low reading. If there are multiple spade terminals, remove them one at a time to find which one is grounded. One of them is bad, it is just a matter of finding the bad one and then fixing what is wrong. Tom EDIT: Quick check - pull the cig lighter out and see if there is corrosion inside. With lighter out does the reading on the load side of fuse #8 get higher in ohms? Tom Preliminary testing had the powered side of fuse slot eight at 1 ohm and the unpowered side at 0 ohm's. It didn't make a difference if the lighter was in or out. Is that enough resistence to cause fault? |
Lo-Fi Version | Time is now: 7th July 2025 - 12:44 AM |
