> Interesting Electrical/Charging Issue
GregAmy
post Jun 15 2014, 04:47 PM
1974 2L 914. "Driver" condition, way far from concourse, but drives well. I've noticed from the beginning a relay clicking under the dash; at first I thought I left my turn signal on, but it's not. It didn't seem to bother anything so I ignored it.
Couple nights ago I drove it for the first time at night. It was then I noticed the "gen" light was glowing very faintly, and at idle I'd hear the click and the light would get brigth(er), then slowly dim. Then it would click again, get bright(er), then dim.
I've also noticed from the beginning that the voltmeter would show 13+ volts normally, except when I stepped on the brake; when I did that it would go below 12. Same thing happened when I flipped on the lights. Strangely, when I did either, the clicking would stop...
Today I did some basic troubleshooting. Had my assistant sit in the car and I measured voltage directly at the battery. At idle, center console gauge shows ~13v, VOM showed 13.75. Good. Asked Vanna to step on the brakes; gauge showed ~11.8V, battery showed 13.4. Asked her to turn on headlights and stay on brake; center voltmeter showed ~11.5, battery had 12.3-12.5. Asked her to rev it, battery voltage got up to ~12.7.
So it really doesn't sound like I have a charging issue, it sounds like there's something going on under the dash.
I'm gonna guess you're gonna tell me it's a ground under the dash. But can you offer where I might find that? Or where I can run one to supplement it? The battery (from a Miata) has been moved to the rear trunk; it's positive cable goes directly to the starter and its ground to the ground stud under the rear trunk. The ground strap from that stud to the transaxle is very good, I've removed, cleaned, and re-attached it.
Car seems to be running fine, starts, drives, charges. I'm just looking to get accurate readings from the gauge and to stop that clicking...
Thanks!
Greg
stugray
post Jun 30 2014, 09:24 PM
Sounds like you have a "soft short" in the flasher circuit.
(soft meaning it is a load, not zero ohms or "hard" short)
When the flasher circuit is energized, it pulls so much current that the voltage is drooping on that side of the Alt light circuit.
A voltage difference in either direction is what makes the Alt light illuminate.
You could tell which side of the alt light the drop is on by checking the voltage across the light when it is lit.
This will tell you which way the current is flowing and help you isolate the probelm.
GregAmy
post Jul 1 2014, 07:46 AM
QUOTE(stugray @ Jun 30 2014, 11:24 PM) *
And I wonder if this may be related?
http://forums.pelicanparts.com/porsche-914...al-problem.html
An incorrectly-grounded wire would explain one relay "buzzing" and the other cycling and causing the gen light to cycle.
So in addition to checking everything else, I guess I'm pulling out all the turn signal circuits to ensure they're terminated correctly...
GA
- Lo-Fi Version Time is now: 7th March 2026 - 04:16 AM
