| Gcotton92203 |
Jun 30 2014, 08:25 PM
Newbie ![]() Group: Members Posts: 21 Joined: 14-February 14 From: Bermuda Dunes Ca. Member No.: 17,000 Region Association: Southern California |
OK, I'm new to this forum stuff & have absolutely no idea what I'm doing but here goes. Just got a bad running 73 2.0 and found that the only actual problem was burnt and out of adjustment ignition points. I replaced them, dialed in the dwell at 45 and the car ran fine but of course I thought I should recheck the timing. I scratch marked the original position of the distributor before moving it. Vacuum hoses are disconnected and plugged. Can't get the idle below 1100 warm but it idles pretty smoothly so I don't see that as a problem. Here's the kicker. It's showing the timing as already 27 degrees advanced at "IDLE"???? If I set it a 27 degrees at 3500 it is so retarded it just dies at throttle down. So when I have it running & idling good, I have absolutely no idea what the timing and advance really is. The last thing I want to do is damage my engine from improper timing. Any help would be greatly appreciated. Thanks
| McMark |
Jul 1 2014, 11:21 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Perhaps your fan has spun on the crank. It's happened before. Confirm with the flywheel mark or by pulling the #1 spark plug and watching/feeling the piston to confirm TDC.
Gcotton92203 Crazy timing Jun 30 2014, 08:25 PM
stugray How are you checking the advance?
With a variable ... Jun 30 2014, 09:28 PM
McMark Yup, that's a pretty good summary. Jun 30 2014, 11:42 PM
Gcotton92203
I can see... Jul 1 2014, 09:13 PM
Gcotton92203
Perhaps your fan has spun on the crank. It's... Jul 3 2014, 05:54 PM
Java2570 Type 4 has the woodruff key on the crank to locate... Jul 3 2014, 06:04 PM
r_towle The flywheel won't shear.
Check TDC via the re... Jul 4 2014, 09:48 AM![]() ![]() |
Lo-Fi Version | Time is now: 7th November 2026 - 04:44 PM |
