Milkman7286 |
Newbie ![]() Group: Members Posts: 30 Joined: 1-July 14 From: Missoula, MT Member No.: 17,571 Region Association: None ![]() |
Hello all,
I've got a 71 4 banger with dual weber idf 44's on it and the driver's side front barrel has sprung a leak. Here is a little detail before I go further into the leak: The webers are about 6 years old and have about 7,000 miles on them. The car sat in storage for about 3 years but was started and driven every 6 months or so. For all I know this leak has been there all along and I never noticed, but I don't think that is the case. The leak: The carb is leaking gas down the front barrel on the drivers side. It appears to be coming from the progression / transition holes but it is hard to tell. The other thing I noticed is that the gasket just above the float bowl is very wet and the gasket between the carb/manifold is also a little wet. I have been dealing with this for about 2 weeks now and have read every possible thing I can find and none have solved this. Here is what I have done so far: -Float set at 10.5mm measuring with the gasket in place. -Butterfly was loosened and repositioned in the bore. -Needle and seat have been tested both with fuel and air and are good -float is free in movement and does not hang up in the bowl -float is still a float and does not sink -idle circuit is free flowing and not clogged -fuel pressure is 2.5 -float bowl gasket does not accidentally cover any holes or vents Any ideas on this one? I feel like I have tried everything and for the life of me I can't figure it out. Last night I was watching the fuel puddle on top of the butterfly and it seemed like maybe it was coming from the seam at the float bowl gasket. Any reason why fuel would be coming from there? As FYI: This happens when the car is hot or cold, doesn't matter. |
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
Would bad gaskets cause something like this? Gaskets should be changed every time you crack the top. Fuel sloshing around in the float bowl could leak around a bad gasket or a warped top. How new are these carbs? Do you have a pic of one of them, preferably from the float bowl side? You thinking inferior casting? |
Milkman7286 |
Would bad gaskets cause something like this? Gaskets should be changed every time you crack the top. Fuel sloshing around in the float bowl could leak around a bad gasket or a warped top. How new are these carbs? Do you have a pic of one of them, preferably from the float bowl side? You thinking inferior casting? So it sounds like the gaskets aren't the issue despite needing to be replaced. This happens when the car is off so no fuel pump going. Just a quick update to all: Last night I lowered the fuel pressure a tiny bit and also set the float height to a little lower (more like 12mm with the gasket in place now) just to see what would happen. Took it for a spin and came back. When I got back I didn't hear anything immediately but I didn't take the filter off to visibly check either. I cracked the throttle by hand however and let it close and after doing so the carb began to gurgle so apparently neither of my changes made a difference. |
Lo-Fi Version | Time is now: 15th July 2025 - 06:11 AM |
