| tadink |
Jun 28 2014, 01:11 PM
Member ![]() ![]() Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California |
ugh -
coming down my road last night - just riding the compression down the hill - flashing BIG red light above the fuel gauge, alternator light on too! Then all three red, green and big red flash together. I shut down and coasted to the bottom - fired back up to get safe, started and ran, alt light on. this morning - check the alt belt - fine and tight. Check the oil - barely registers on the dipstick and dark. Two days ago - clean and on the full mark! uh oh. 1976 2.0L engine with the smog stuff removed. will have it towed to McMark and see what's up on SUNDAY - This is bad, right? There's no knocking or clunking, and no evidence of a massive oil dump anywhere - bottom of engine not coated as far as I can tell. (IMG:style_emoticons/default/confused24.gif) sigh - anyone have a spare 2.0L laying around you're not using? what do guys think went wrong - hoping for the best....fearing the worst. td |
| tadink |
Jul 2 2014, 10:01 AM
<<UPDATE>>
I'm pretty sure I did not imagine this event - however - the mechanic I took it too says they could find nothing wrong. sigh. (mcmark was full) he says the Oil was maybe 1/2 quart low (car was slightly headed uphill when I took the reading, barely reached the bottom of the dipstick). He fired her up, no knocks or noise, alt and oil pressure lights not on. Drove fine, he could not duplicate the event. So - head scratching time - What does the large RED idiot light on the top of the std cluster tie in to? The one above the gas gauge - Under what conditions would all three Alt - Oil pressure - Idiot Light blink simultaneously? It was a hot day - is there an overheat condition that might throw an alert to the driver via these lights? Some 'bright spark' tied in a stereo at some point (now gone), and so when I use the turn signals that large idiot light blinks along with them, ditto for the emergency flashers, so something is cross wired on the fuse panel I suspect. I'll look there first - this is a '71 tub with orig panel. Any other thoughts? gremlins, poltergeist, witch? I may have to do a white sage smoke spiritual cleansing if all else fails.....:-) thx td |
| SirAndy |
Jul 2 2014, 11:26 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,454 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Some 'bright spark' tied in a stereo at some point (now gone), and so when I use the turn signals that large idiot light blinks along with them, ditto for the emergency flashers, so something is cross wired on the fuse panel I suspect. I'll look there first - this is a '71 tub with orig panel. That sounds more like it. Did you use the original screws to mount the fuse panel? Early cars have a *HOT* terminal right above the left side screw and if you're using one that is too long you can short out your fuse panel. Unhook the battery and drop the fuse panel and look for burnt wire ... (IMG:style_emoticons/default/smash.gif) |
| tadink |
Jul 2 2014, 12:09 PM
Some 'bright spark' tied in a stereo at some point (now gone), and so when I use the turn signals that large idiot light blinks along with them, ditto for the emergency flashers, so something is cross wired on the fuse panel I suspect. I'll look there first - this is a '71 tub with orig panel. That sounds more like it. Did you use the original screws to mount the fuse panel? Early cars have a *HOT* terminal right above the left side screw and if you're using one that is too long you can short out your fuse panel. Unhook the battery and drop the fuse panel and look for burnt wire ... (IMG:style_emoticons/default/smash.gif) ahhhh, will do that first. Have not looked at all at this fuse panel, the PO must have made some 'modifications' when he put the stereo in. thanks Sir Andy! td |
tadink Engine failure? Jun 28 2014, 01:11 PM
Mblizzard I would drain the remaining oil out and check it f... Jun 28 2014, 01:21 PM
injunmort I am an optimist, I would drain the oil and check ... Jun 28 2014, 03:32 PM
jmill
... Jun 28 2014, 03:43 PM
tadink
... Jun 28 2014, 03:56 PM
McMark Two options. Burned it or dumped it on the ground... Jun 28 2014, 09:04 PM
wndsnd Thats the difference between hobbyists and profess... Jun 29 2014, 09:25 AM
tadink HUH!? Whaddaya know, and now I learned what a... Jun 29 2014, 10:40 PM
The Cabinetmaker No r in galley folks. Damn spell check! Jun 30 2014, 11:00 AM
Dave_Darling
Not... Jun 30 2014, 07:43 PM
McMark
Says you. Prove it. :P Jun 30 2014, 04:35 PM
tadink well neither one makes any sense to me -
a GALLE... Jun 30 2014, 07:48 PM
SirAndy a GALLERY is a place to look at art
That is a rat... Jun 30 2014, 08:11 PM
maf914
That is a ra... Jul 1 2014, 06:50 AM
rgalla9146 Had a girlfriend a long time ago who started her 9... Jul 1 2014, 07:20 AM
SirAndy What does the large RED idiot light on the top of ... Jul 2 2014, 11:24 AM
stugray Read this thread:
http://www.914world.com/bbs2/in... Jul 2 2014, 01:58 PM
injunmort as I said before, I have had all the lights come o... Jul 2 2014, 02:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th March 2026 - 04:14 AM |
