| SKL1 |
Jul 3 2014, 01:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,772 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest
Putting in new H4 headlights with the 100W high beam and utilizing the "relay" to protect the OEM wiring.
Using the relay and new lights from Pelican and have checked and rechecked my wiring several times. Fused power from battery to #30. #85 to ground. #87 to high beam terminal of each light, #86 to old headlight wiring on one side, and taped off the other as recommended. I have 12V into relay when high beams are on, and good 12V from battery, but neither high beam works thru the system, though low beams work. Fuses all good- new JWest fuse panel. Bulbs new and work fine when bench tested. Any ideas???? Have 2 new relays from Pelican and have tried both... ('73 2.0) |
| Luke M |
Jul 3 2014, 02:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,482 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
I found this drawing awhile back.
Hope it helps. Attached image(s)
SKL1 H4 headlight relay question Jul 3 2014, 01:22 PM
Cap'n Krusty You need one relay for the low beam, one for the h... Jul 3 2014, 01:32 PM
ClayPerrine :agree:
For one side you will need two relays, ... Jul 3 2014, 01:47 PM
ClayPerrine That is a good diagram, with one flaw.
The origin... Jul 3 2014, 02:47 PM
SKL1 great suggestions guys!!
another project ... Jul 3 2014, 02:56 PM
Dave_Darling You don't have to have relays for the low beam... Jul 3 2014, 02:57 PM
Drums66 .....Low watt H-4's,,,,no relay's(I have n... Jul 4 2014, 01:24 PM
SKL1 This car will spend its life in AZ- it is VERY da... Jul 4 2014, 02:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th March 2026 - 05:11 AM |
