> Crazy timing, 27 degrees at idle
Gcotton92203
post Jun 30 2014, 08:25 PM
OK, I'm new to this forum stuff & have absolutely no idea what I'm doing but here goes. Just got a bad running 73 2.0 and found that the only actual problem was burnt and out of adjustment ignition points. I replaced them, dialed in the dwell at 45 and the car ran fine but of course I thought I should recheck the timing. I scratch marked the original position of the distributor before moving it. Vacuum hoses are disconnected and plugged. Can't get the idle below 1100 warm but it idles pretty smoothly so I don't see that as a problem. Here's the kicker. It's showing the timing as already 27 degrees advanced at "IDLE"???? If I set it a 27 degrees at 3500 it is so retarded it just dies at throttle down. So when I have it running & idling good, I have absolutely no idea what the timing and advance really is. The last thing I want to do is damage my engine from improper timing. Any help would be greatly appreciated. Thanks
Java2570
post Jul 3 2014, 06:04 PM
Type 4 has the woodruff key on the crank to locate the fan hub & cooling fan...the keys can
shear, it has happened. Two weeks ago, I noticed a light scraping sound coming from my engine.
Pulled it out and found the cooling fan was coming loose and contacting the fan shroud. Also, the
locating pin on the fan hub was broken off. My woodruff key was still intact though....
- Lo-Fi Version Time is now: 7th November 2026 - 04:44 PM
