> License plate and dash lights on with key on, but lheadlight switch in the off position
HalfMoon
post Jun 23 2014, 07:50 PM
I started my car tonight and noticed despite the headlight switch being fully in the off position, my dash lights are on and my license plate light is .
Odd. Never saw that before. Headlight switch I imagine....
Thoughts?
David
Addedum-and saw what I thought was a wisp of smoke come from under my dash at the windshield....perhaps my imagination?
Tom
post Jul 4 2014, 03:00 PM
Remember that 53a goes to both your wiper motor and the fresh air blower. 1.9 ohms seems an OK reading to me. If the spare that tested OK on the bench does not work in the car, I would investigate that wiper switch.
Tom
HalfMoon   License plate and dash lights on with key on   Jun 23 2014, 07:50 PM
dangrouche   Here is the bird board repair of the switch; I...   Jun 23 2014, 08:11 PM
HalfMoon   Here is the bird board repair of the switch; I...   Jun 23 2014, 08:41 PM
HalfMoon   Hmmm.... odd question. Is the wiper switch and the...   Jun 25 2014, 03:49 PM
Dave_Darling   The two switches do work with each other, in that ...   Jun 25 2014, 03:54 PM
HalfMoon   The two switches do work with each other, in that...   Jun 25 2014, 03:56 PM
Dave_Darling   Wiring diagrams: http://www.pelicanparts.com/914/...   Jun 25 2014, 05:55 PM
HalfMoon   Wiring diagrams: http://www.pelicanparts.com/914...   Jun 25 2014, 08:06 PM
HalfMoon   Interesting. http://www.914world.com/bbs2/index.ph...   Jun 25 2014, 08:56 PM
GeorgeRud   I may be way out there, but doesn't the light ...   Jun 25 2014, 09:31 PM
HalfMoon   I may be way out there, but doesn't the light...   Jun 25 2014, 09:54 PM
HalfMoon   Ok. So I've fouund (in my manual of all place,...   Jun 25 2014, 09:47 PM
john77   I have a 73 that also came with mixed up relays. O...   Jun 26 2014, 12:50 AM
HalfMoon   ...and then the three black ones are for fogs, ho...   Jun 26 2014, 11:27 AM
ovilla   HalfMoon, I have the exact same issue as you and a...   Jun 26 2014, 12:53 AM
Dave_Darling   Sorry, I just noticed a typo! The third of th...   Jun 26 2014, 08:45 AM
HalfMoon   Sorry, I just noticed a typo! The third of t...   Jun 26 2014, 11:24 AM
HalfMoon   Somewhat academic at this point as I've repl;a...   Jun 26 2014, 01:14 PM
HalfMoon   The mystery relay Addedum-relay number 002479-01...   Jun 26 2014, 01:22 PM
rmital   [quote name='HalfMoon' post='2054661...   Sep 19 2020, 08:30 AM
TheVintagePassion   Hello at all, I'm Carmine Borraccino From Ital...   Oct 8 2020, 01:35 AM
rmital   Hello at all, I'm Carmine Borraccino From Ita...   Oct 8 2020, 12:06 PM
Dave_Darling   Much clearer pics, thanks! D has a red, a red...   Jun 26 2014, 04:19 PM
HalfMoon   Much clearer pics, thanks! D has a red, a re...   Jun 26 2014, 06:28 PM
dadaDaveed   [quote name='Dave_Darling' post='2054726' date='J...   Jun 26 2014, 09:18 PM
HalfMoon   [quote name='Dave_Darling' post='2054726' date='...   Jun 26 2014, 09:44 PM
HalfMoon   Process of elimination. I swapped in a spare (and ...   Jun 26 2014, 07:50 PM
Jeff Bowlsby   Here are some testing diagrams for the dash switch...   Jun 26 2014, 09:26 PM
HalfMoon   Here are some testing diagrams for the dash switc...   Jun 26 2014, 09:48 PM
HalfMoon   Today I thought I would pull the headlight dimmer ...   Jun 28 2014, 12:31 PM
dadaDaveed   Today I thought I would pull the headlight dimmer...   Jun 28 2014, 12:59 PM
HalfMoon   Today I thought I would pull the headlight dimme...   Jun 28 2014, 09:11 PM
dadaDaveed   I just pulled my fuse panel to take a look. 56 ...   Jun 28 2014, 09:31 PM
dadaDaveed   Honestly, I don't know if swapping 56a and 56b...   Jun 28 2014, 09:36 PM
HalfMoon   Honestly, I don't know if swapping 56a and 56...   Jun 28 2014, 09:45 PM
HalfMoon   Made the dimmer switch tonight but no love. Fuses ...   Jun 29 2014, 09:27 PM
Dave_Darling   Look for places (especially lights) where wires co...   Jun 29 2014, 10:18 PM
Tom   You need to find out why fuse #8 is blowing, Accor...   Jun 30 2014, 06:31 AM
HalfMoon   You need to find out why fuse #8 is blowing, Acco...   Jun 30 2014, 08:08 PM
Tom   "0" ohms from the load side of the fuse ...   Jul 1 2014, 12:22 AM
HalfMoon   "0" ohms from the load side of the fuse...   Jul 1 2014, 09:25 AM
Tom   David, The "load" side of a fuse i...   Jul 1 2014, 11:37 AM
HalfMoon   David, The "load" side of a fuse ...   Jul 1 2014, 12:52 PM
HalfMoon   Working on an assumption that each component wire ...   Jul 1 2014, 01:28 PM
Tom   David, First of all, you need to separate all...   Jul 1 2014, 06:19 PM
HalfMoon   David, First of all, you need to separate al...   Jul 1 2014, 07:19 PM
HalfMoon   Did more testing today per Tom's recommendatio...   Jul 2 2014, 02:43 PM
Tom   Sounds like a bad wiper motor to me. A good one sh...   Jul 2 2014, 08:36 PM
HalfMoon   Sounds like a bad wiper motor to me. A good one s...   Jul 3 2014, 12:13 PM
HalfMoon   Interesting afternoon out in the garage with Littl...   Jul 3 2014, 07:27 PM
Tom   David, Glad to see you now know what the proble...   Jul 4 2014, 12:28 AM
HalfMoon   David, Glad to see you now know what the probl...   Jul 4 2014, 02:01 PM
Tom   Remember that 53a goes to both your wiper motor an...   Jul 4 2014, 03:00 PM
Tom   David, I was reading back thru some of your ...   Jul 5 2014, 01:32 PM
HalfMoon   David, I was reading back thru some of your...   Jul 5 2014, 01:56 PM
HalfMoon   Rats. I hooked up my spare to the cars harness (an...   Jul 5 2014, 01:58 PM
Tom   David, Well, that clears up the readings! T...   Jul 5 2014, 06:21 PM
HalfMoon   David, Well, that clears up the readings! ...   Jul 6 2014, 01:35 PM
Tom   David, Does your blower motor work? The blower ...   Jul 6 2014, 02:02 PM
HalfMoon   David, Does your blower motor work? The blower...   Jul 6 2014, 02:27 PM
Tom   David, Are those wires properly terminated to k...   Jul 6 2014, 03:19 PM
HalfMoon   David, Are those wires properly terminated to ...   Jul 6 2014, 09:11 PM
HalfMoon   Actually..... Friend Valy has suggested disconnect...   Jul 6 2014, 11:40 PM
HalfMoon   Got out in the shop for a bit today and performed ...   Jul 7 2014, 03:09 PM
HalfMoon   Hmpf. Pretty confused today. I did a side by side ...   Jul 7 2014, 07:58 PM
HalfMoon   Swapped out the new 924 switch from my 1973 for n...   Jul 7 2014, 10:38 PM
Tom   Progress! That's good. Not take voltage m...   Jul 8 2014, 04:04 AM
HalfMoon   Progress! That's good. Not take voltage ...   Jul 8 2014, 10:34 AM
HalfMoon   Found something interesting. A continuity problem ...   Jul 8 2014, 06:17 PM
HalfMoon   Well duh me. On the learning curve. Slot 5 of the...   Jul 9 2014, 06:15 PM
HalfMoon   Sigh. Well it has been a long long road but my wip...   Aug 4 2014, 10:06 PM
76-914   Sigh. Well it has been a long long road but my wi...   Aug 5 2014, 08:11 AM
HalfMoon   Oh, btw, if anyone would be interested in verifyin...   Aug 4 2014, 10:08 PM
dangrouche   after reading your thread, I thought about offerin...   Aug 4 2014, 11:18 PM
HalfMoon   after reading your thread, I thought about offeri...   Aug 4 2014, 11:28 PM
rhodyguy   what's the story with the grey exposed wire in...   Aug 5 2014, 01:28 PM
HalfMoon   what's the story with the grey exposed wire i...   Aug 5 2014, 02:46 PM
- Lo-Fi Version Time is now: 7th July 2025 - 12:58 AM
