| boxsterfan |
Jul 4 2014, 01:47 PM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
On my way home on the freeway last night, my 74 2.0L just died travelling along at 70 MPH. Had her towed home.
Looking at it today, it appears there is no spark. If I turn the key, I can hear the fuel pump so seems like I got power there. I have a newer Bosch coil from PP that I put in a few months ago (it's one of those silver looking ones but a Bosch unit). I replaced the coil back with the old one and still no start. Car cranks, but no fire. The car has Pertronix in it. I suspect this is what died. Does that sound right to the folks here? |
| boxsterfan |
Jul 4 2014, 06:16 PM
So I checked for spark by pulling the #1 plug wire, hooking up to spark plug directly, vampire clip in the spark end of the plug and a wire that I ground to the body. I had a helper cranking the motor for me.
I saw spark there, but is sure seemed awful weak. I've never seen the spark on a plug outside the motor. And of course, my ground could have been poor also as i was just rigging this up to see if there was any spark. How "strong" should the spark be or look? Otherwise I got spark (weak?), and I hear the fuel pump running, then what's next? This is a 74 with the "seatbelt relay" under the passenger seat. These things are famous for causing issues. One time, mine caused the car to not start (except the symptom was that it wouldn't even crank). I ended up re-seating all the connections under there (6 months ago) and had been fine until now. Otherwise? I dunno... (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
| Bartlett 914 |
Jul 4 2014, 06:25 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
So I checked for spark by pulling the #1 plug wire, hooking up to spark plug directly, vampire clip in the spark end of the plug and a wire that I ground to the body. I had a helper cranking the motor for me. I saw spark there, but is sure seemed awful weak. I've never seen the spark on a plug outside the motor. And of course, my ground could have been poor also as i was just rigging this up to see if there was any spark. How "strong" should the spark be or look? And I got spark, and I hear the fuel pump running, then what's next? This is a 74 with the "seatbelt relay" under the passenger seat. These things are famous for causing issues. One time, mine caused the car to not start (except the symptom was that it wouldn't even crank). I ended up re-seating all the connections under there (6 months ago) and had been fine until now. Otherwise? I dunno... (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) Seatbelt relay will prevent the engine from cranking. Since you can crank, that isn't your problem. |
boxsterfan Diagnose no start Jul 4 2014, 01:47 PM
Jeff Bowlsby Those are notorius for dying. Try a set of points... Jul 4 2014, 02:12 PM
Mblizzard Have you verified the lack of spark? Just checkin... Jul 4 2014, 02:15 PM
boxsterfan
Have you verified the lack of spark? Just checki... Jul 4 2014, 02:23 PM
Mblizzard If you work alone a lot set yourself up a remote s... Jul 4 2014, 02:45 PM
Java2570 Check the ground wire that runs between the points... Jul 4 2014, 07:17 PM
boxsterfan
Check the ground wire that runs between the point... Jul 4 2014, 08:00 PM
Mblizzard Ok some good suggestions. But I would check the w... Jul 4 2014, 07:57 PM
boxsterfan
Ok some good suggestions. But I would check the ... Jul 4 2014, 08:03 PM
boxsterfan I went at looked at the ground strap on the contac... Jul 4 2014, 09:02 PM
Java2570 Ground in dizzy appears ok.....pretty dirty in the... Jul 4 2014, 09:43 PM
boxsterfan
Ground in dizzy appears ok.....pretty dirty in th... Jul 4 2014, 10:04 PM
Jeff Bowlsby I should have an extra set of points if you need t... Jul 4 2014, 10:28 PM
boxsterfan So this morning, I checked over everything again:
... Jul 5 2014, 12:13 PM
Jeff Bowlsby http://members.rennlist.com/pbanders/FPChecklist_f... Jul 5 2014, 12:26 PM
Bartlett 914 Spray some starter fluid or brake cleaner in the i... Jul 5 2014, 12:45 PM
Java2570 The fuel pump should kick on for a second or so wh... Jul 5 2014, 02:11 PM
boxsterfan So I finally got the 2.0L started again. Fuel pump... Jul 5 2014, 07:51 PM
Java2570 I believe the AAR circuit is connected to the fuel... Jul 5 2014, 08:00 PM
boxsterfan
I believe the AAR circuit is connected to the fue... Jul 5 2014, 08:11 PM
Mike Bellis The brake light warning circuit is active; Blinkin... Jul 5 2014, 08:05 PM
boxsterfan
The brake light warning circuit is active; Blinki... Jul 5 2014, 08:10 PM
boxsterfan A follow up question about fuel pump power:
So lo... Jul 6 2014, 03:33 PM
Dave_Darling Best guess is the PO wired the pump to a switched ... Jul 6 2014, 10:33 PM
Tom Easy test - pull the fuel pump relay on the relay ... Jul 7 2014, 12:15 AM
boxsterfan After I replace my relay board and look for any ot... Jul 7 2014, 09:30 PM
Garold Shaffer Sent you a PM, but before you go replacing the fue... Jul 7 2014, 11:19 PM
boxsterfan
Sent you a PM, but before you go replacing the fu... Jul 8 2014, 08:19 AM
Dave_Darling
I'm starting with the relay board (heck its 4... Jul 8 2014, 11:49 AM
Java2570 If your fuel lines haven't been replaced, do i... Jul 8 2014, 09:25 AM
boxsterfan
If your fuel lines haven't been replaced, do ... Jul 8 2014, 09:15 PM
ClayPerrine This should help with the fuel pump troubleshootin... Jul 8 2014, 02:41 PM
boxsterfan
This should help with the fuel pump troubleshooti... Jul 8 2014, 09:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:30 PM |
