| boxsterfan |
Jul 4 2014, 01:47 PM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
On my way home on the freeway last night, my 74 2.0L just died travelling along at 70 MPH. Had her towed home.
Looking at it today, it appears there is no spark. If I turn the key, I can hear the fuel pump so seems like I got power there. I have a newer Bosch coil from PP that I put in a few months ago (it's one of those silver looking ones but a Bosch unit). I replaced the coil back with the old one and still no start. Car cranks, but no fire. The car has Pertronix in it. I suspect this is what died. Does that sound right to the folks here? |
| Java2570 |
Jul 8 2014, 09:25 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
If your fuel lines haven't been replaced, do it now while you're in there....I'm in process of doing all the lines and couldn't believe how bad my rubber lines to the tank were. One was kinked over and split all the way to the woven core; I can't believe it wasn't leaking! The SS tunnel lines are pretty easy to install and there was a minimum of swearing, which is uncommon for me! And I did get a couple of gas cans full of gas for the mower: bonus!
boxsterfan Diagnose no start Jul 4 2014, 01:47 PM
Jeff Bowlsby Those are notorius for dying. Try a set of points... Jul 4 2014, 02:12 PM
Mblizzard Have you verified the lack of spark? Just checkin... Jul 4 2014, 02:15 PM
boxsterfan
Have you verified the lack of spark? Just checki... Jul 4 2014, 02:23 PM
Mblizzard If you work alone a lot set yourself up a remote s... Jul 4 2014, 02:45 PM
boxsterfan So I checked for spark by pulling the #1 plug wire... Jul 4 2014, 06:16 PM
Bartlett 914
So I checked for spark by pulling the #1 plug wir... Jul 4 2014, 06:25 PM
Java2570 Check the ground wire that runs between the points... Jul 4 2014, 07:17 PM
boxsterfan
Check the ground wire that runs between the point... Jul 4 2014, 08:00 PM
Mblizzard Ok some good suggestions. But I would check the w... Jul 4 2014, 07:57 PM
boxsterfan
Ok some good suggestions. But I would check the ... Jul 4 2014, 08:03 PM
boxsterfan I went at looked at the ground strap on the contac... Jul 4 2014, 09:02 PM
Java2570 Ground in dizzy appears ok.....pretty dirty in the... Jul 4 2014, 09:43 PM
boxsterfan
Ground in dizzy appears ok.....pretty dirty in th... Jul 4 2014, 10:04 PM
Jeff Bowlsby I should have an extra set of points if you need t... Jul 4 2014, 10:28 PM
boxsterfan So this morning, I checked over everything again:
... Jul 5 2014, 12:13 PM
Jeff Bowlsby http://members.rennlist.com/pbanders/FPChecklist_f... Jul 5 2014, 12:26 PM
Bartlett 914 Spray some starter fluid or brake cleaner in the i... Jul 5 2014, 12:45 PM
Java2570 The fuel pump should kick on for a second or so wh... Jul 5 2014, 02:11 PM
boxsterfan So I finally got the 2.0L started again. Fuel pump... Jul 5 2014, 07:51 PM
Java2570 I believe the AAR circuit is connected to the fuel... Jul 5 2014, 08:00 PM
boxsterfan
I believe the AAR circuit is connected to the fue... Jul 5 2014, 08:11 PM
Mike Bellis The brake light warning circuit is active; Blinkin... Jul 5 2014, 08:05 PM
boxsterfan
The brake light warning circuit is active; Blinki... Jul 5 2014, 08:10 PM
boxsterfan A follow up question about fuel pump power:
So lo... Jul 6 2014, 03:33 PM
Dave_Darling Best guess is the PO wired the pump to a switched ... Jul 6 2014, 10:33 PM
Tom Easy test - pull the fuel pump relay on the relay ... Jul 7 2014, 12:15 AM
boxsterfan After I replace my relay board and look for any ot... Jul 7 2014, 09:30 PM
Garold Shaffer Sent you a PM, but before you go replacing the fue... Jul 7 2014, 11:19 PM
boxsterfan
Sent you a PM, but before you go replacing the fu... Jul 8 2014, 08:19 AM
Dave_Darling
I'm starting with the relay board (heck its 4... Jul 8 2014, 11:49 AM
boxsterfan
If your fuel lines haven't been replaced, do ... Jul 8 2014, 09:15 PM
ClayPerrine This should help with the fuel pump troubleshootin... Jul 8 2014, 02:41 PM
boxsterfan
This should help with the fuel pump troubleshooti... Jul 8 2014, 09:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:24 PM |
