| jacksun |
Jul 7 2014, 06:10 PM
Member ![]() ![]() Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest |
| Dave_Darling |
Jul 8 2014, 11:53 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
The lower part of the spring should rest on the shoulders of the tube, and not poke down into the tube. If the spring does poke down the tube, you can use a hook to pull the spring outward, and it should catch on the shoulders of the tube.
Failing to do so can result in a nice notch near the end of your pushrods, ad the steel spring grinds away the aluminum rod. --DD |
jacksun what to use? Jul 7 2014, 06:10 PM
StratPlayer I just put a little oil on mine on a fresh rebuild... Jul 7 2014, 06:49 PM
stugray I use loctite 565 teflon thread sealant (NON-harde... Jul 7 2014, 07:17 PM
jacksun tks for the replies..
the thread on "paint... Jul 8 2014, 05:52 AM
stugray Both sides. Just coat the oring.
With that stuff, ... Jul 8 2014, 07:17 AM
jacksun thank you Jul 8 2014, 07:37 AM
stugray The next question should be:
How do these spring ... Jul 8 2014, 07:55 AM
jacksun thank you for the info..
I only removed one side ... Jul 8 2014, 04:29 PM
Elliot Cannon These guys built my engine and this is what they u... Jul 8 2014, 04:39 PM
Dave_Darling So they've been doing it wrong for 30 years...... Jul 8 2014, 10:56 PM
Elliot Cannon
So they've been doing it wrong for 30 years..... Jul 9 2014, 12:13 AM
ClayPerrine I use a little plain, ordinary wheel bearing greas... Jul 9 2014, 05:50 AM
9146986 I'll 2nd the Loctite 565. It's a tip I go... Jul 9 2014, 07:15 AM
Jake Raby I've done it many ways. No matter what method ... Jul 9 2014, 07:37 AM
Mark Henry I now use DOW Corning Molykote 55 seems to work go... Jul 9 2014, 07:58 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:46 PM |
