Running Really Hot on the Track, I don't necessarily mean fast |
ww914 |
May 10 2014, 03:51 PM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
Yesterday at Buttonwillow for our DE, the temperature was not all that hot, but I could only get in 2 laps at race speed before my CHT gauge started hollering at me. Here are the maximum values from yesterday:
Cyl #1 384 degrees Cyl #2 357 degrees Cyl #3 433 degrees Cyl #4 402 degrees I have the alarm set at 400 degrees, so each time it reached that temp, I backed off and let it cool down and finished each session with just a Sunday drive. Here's what I have: My engine is a 2270 built by Original Customs 2 40 DLRAs: 150 main jets 180 air correction jets 34 venturis 9164.2 emulsion tubes 75 idle jets 50 pump jets Both carbs are accurately sync'd and the a/f gauge shows between 13 - 14 all through the progression to WOT The timing is set to about 30 degrees I am running a stock cooling system with the thermostat and flaps working properly. I pulled engine tin to look for obstructions. None. I am running a Sebtrab 8 x 10 oil cooler but my temps are over 220 when pushing it hard. No fans. I am not sure where to go from here: alternate cooling, larger oil cooler, fans? Any suggestions would be appreciated. |
PotterPorsche |
May 28 2014, 10:17 PM
Member Group: Members Posts: 295 Joined: 10-November 13 From: Hayward CA Member No.: 16,628 Region Association: None |
Have you tried 180 air 160 mains or possible 190 airs 155 mains. Interested in the WOT numbers Also what venturis? 32mm i assume
ww914 |
May 29 2014, 08:43 AM
Have you tried 180 air 160 mains or possible 190 airs 155 mains. Interested in the WOT numbers Also what venturis? 32mm i assume I am running 160 mains with 180 A/C which got my WOT at redline a/f readings to around 12.0, through 34 venturis, but the cyl temps were still too high, especially #3. The oil temps were also running too high 230 to 250. I am almost ready to re-install the engine with the few things I found wrong and with Tangerine Racing remote oil cooler kit. We'll see what happens. |
ww914 |
Jul 9 2014, 09:05 AM
Have you tried 180 air 160 mains or possible 190 airs 155 mains. Interested in the WOT numbers Also what venturis? 32mm i assume I am running 160 mains with 180 A/C which got my WOT at redline a/f readings to around 12.0, through 34 venturis, but the cyl temps were still too high, especially #3. The oil temps were also running too high 230 to 250. I am almost ready to re-install the engine with the few things I found wrong and with Tangerine Racing remote oil cooler kit. We'll see what happens. OK, after re-installing the engine with some modifications that I will show you, I believe I have done everything I can do to lower my cyl head temps and oil temps. I think JP Stein may be right about these engines, one can only do so much. Oh, I am sure there is more I could do, but I am not sure I would be getting the bang for the buck. I have already spent a small fortune. Am I where I want to be? Maybe not, but I am definitely feeling better about my temperatures. Here is what I did: When I removed the engine, I found a few minor things wrong that I corrected. I found my missing alternator cover inside the impeller. I also found that I had two blades missing. Corrected both of the problems. I also installed the Tangerine Racing remote oil cooler kit, which eliminates the stock oil cooler and re-routes that air to #3 & 4 cylinders. You can see the plate installed where the air used to go down to the stock oil cooler. I have positioned the oil cooler in several different spots in the rear passenger side of the car. None seemed to work better than others. Here is one of those positions: I then added 3" hose and a NACA duct: It was about this time, I installed Chris Foley's pressure relief valve. Didn't see a big difference, but Chris assures me that oil was now for sure going to the cooler and that is a good thing. I think all these little things add up to more improvement. Next, I made an single inlet shroud to pick up most of the cooler air from the NACA duct. That helped, but I was still not satisfied, so I made a dual inlet shroud and picked up more air from the engine compartment, close to the new GT lid I bought. Here's the shroud on the workbench. Here it is installed. You can see the inline oil thermstat in the above left To be continued......... |
ww914 |
Jul 9 2014, 09:25 AM
Here's another shot:
Here is the engine compartment inlet: Well that's the picture story, but here are the numbers. Before I did any of this, I made sure my A/F mixture was correct. After playing with main jets, I ended up with this: 12.0 at WOT 160 mains, 180 a/c jets and timing at 30 degs My #3 CHT was 397 degrees and my oil temp was 250 degrees with hard driving. This when I removed the engine to install the cooler bypass My CHT on #3 went down to 350 degrees, but my oil temp was still 240 - 250 degrees I then added the manifold to the front of the cooler Oil temp down to about 240 and CHT #3 was 348 I then added the other hose from the engine compartment with the dual inlet shroud and a pair of Spal 5" fans. At 70 - 80 on the freeway I stay at or below 220 degrees HAPPY WITH THIS!!! CHT #3 were still a little high at 360-375 but not bad for running in 4th gear at 80 mph. Foley's is not a big fan of oil cooler fans, but with these fans, it definitely brought my oil temps to an acceptable level. I am convinced that in order to take this car on the track for more than two laps, I would have to move the oil cooler to the front. Any other suggestions are welcomed, but right now for normal freeway driving and auto cross, I am good. I may play with the jetting a little more, but right now I think I will let all of this settle in. |
brant |
Jul 9 2014, 02:33 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I am convinced that in order to take this car on the track for more than two laps, I would have to move the oil cooler to the front. in the last 20 years of playing with these cars.... I've seen it over and over a lot of people (even myself) play with rear coolers and all of the incremental steps to get the temp down. In the end, its more effective and quicker to install a front cooler. But glad you have things under control to where they are manageable. I have literally seen these threads since this website began (and the websites that preceded this one)... folks chipping away at their oil temps and learning on their own time after time that a front cooler, with frontal air is basically necessary for a track car. I know some really amazing fabricators make rear coolers work on the rear of a 914, but its not the quick and easy way to get the job done. |
Lo-Fi Version | Time is now: 10th June 2024 - 11:52 PM |
