Running Really Hot on the Track, I don't necessarily mean fast |
ww914 |
May 10 2014, 03:51 PM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
Yesterday at Buttonwillow for our DE, the temperature was not all that hot, but I could only get in 2 laps at race speed before my CHT gauge started hollering at me. Here are the maximum values from yesterday:
Cyl #1 384 degrees Cyl #2 357 degrees Cyl #3 433 degrees Cyl #4 402 degrees I have the alarm set at 400 degrees, so each time it reached that temp, I backed off and let it cool down and finished each session with just a Sunday drive. Here's what I have: My engine is a 2270 built by Original Customs 2 40 DLRAs: 150 main jets 180 air correction jets 34 venturis 9164.2 emulsion tubes 75 idle jets 50 pump jets Both carbs are accurately sync'd and the a/f gauge shows between 13 - 14 all through the progression to WOT The timing is set to about 30 degrees I am running a stock cooling system with the thermostat and flaps working properly. I pulled engine tin to look for obstructions. None. I am running a Sebtrab 8 x 10 oil cooler but my temps are over 220 when pushing it hard. No fans. I am not sure where to go from here: alternate cooling, larger oil cooler, fans? Any suggestions would be appreciated. |
Racer |
Jul 9 2014, 07:28 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
I am confused about a few things here..
1) I was under the impression that the top side of the 914 engine lid was in a low pressure area. That in fact, the bulk of the cooling air came from the bottom side. Perhaps this moreso in a street car with the rain guard in place. This leads me to really wonder: a) the oil breather catch tank placement should not really impact engine cooling at all and b) if the top side is a low pressure area, why the orange hose from the cooler up thru the engine compartment? 2) Have you been able to confirm that the oilcooler is actually working? Can you get a line temp, inlet and outlet sides of the cooler to know if there is a temp difference? Don't know the class rules you are contsrained by, but I noticed significant oil cooling advantages moving my oil cooler from under the engine lid cover to a front mounted unit that actually got airflow. CHT temps.. maybe a piece of black tape on the guage would help (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 10:50 AM |
