Tab914 |
Member ![]() ![]() Group: Members Posts: 159 Joined: 25-April 04 From: Alexandria, Ontario, Canada Member No.: 1,978 Region Association: Canada ![]() |
Hey guys! Hope someone out there can help me out. I'm having problems with my engine coughing ( missing ) and sputtering when accelerating and also on steady revs at about between 2000 and 3000 rpms. This causes the car to lose power and shutter. The problem is worst once car is warmed up. The car starts great without even having to step on the gas but idle sometimes becomes erratic. I adjusted the dwell, timming ( with strobe ) and idle ( idle as best i could ) but can't put my finger on the problem. I would appreciate any tips, info, or idea anyone might have. Cheers, Dominic.
p.s. I'm in the Canadian rockies, would elevation change specks car should be at?? |
Tab914 |
Thanks Slits! The fuel pump is brand new, I checked the temp. sensor and it is showing the ohms reading. The plugs are good. I have the throttle position sensor in my hands right now. Took it off to check the contacts. Found some corosion and cleaned all of that off. What exactly do you mean by " bad tracks" ? Also is it possible to test the switch with a meter while it is out of the car? If so how? I will have another look at the plug wires and inside the cap. Might also use the fireworks method in the dark just for the hell of it.
Lo-Fi Version | Time is now: 17th July 2025 - 03:36 AM |
