lmcchesney |
Member ![]() ![]() Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None ![]() |
I replaced the oil pressure sender on the top of my case with a sender which provides light activation and VDO oil pressure reading. How do I know which pole is for the light and which is for the pressure gauge?
The gauge also has three connectors for the gauge (not the connector for the light) which is marked +, G and grnd. What connects to what? Thanks, L. McC |
Walter |
Member ![]() ![]() Group: Members Posts: 70 Joined: 10-August 04 From: The Netherlands, Europe Member No.: 2,499 ![]() |
QUOTE(ArtechnikA @ Aug 6 2004, 07:08 AM) QUOTE(lmcchesney @ Aug 6 2004, 06:49 AM) + - switched (Terminal 15) +12VDC G - Gauge grnd - ground Well, actually, the G stands for 'Geber'. 'Geben' is German for 'to give', so it is the pole that gives the information...but ' Gauge' will be fine as well (IMG:style_emoticons/default/biggrin.gif) Just teflon tape it for sealing and groud the sender to something else. Anybody did this similar? Greetings, Walter |
Lo-Fi Version | Time is now: 14th July 2025 - 10:40 PM |
