tuning d-jet 2.0('75) - A/F ratio, effects on engine temp, Am i running lean on highway?- 14.0 @ 65-70 mph |
DRPHIL914 |
Jul 16 2014, 06:51 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
So i've been able to observe my A/F ratio for the past 2 weeks, driving the car daily to work and some short trips of 30-75 miles.
yesterday evening, with the outside temp being @ 90, i noticed that as i increased my speed from @ 60mph i was running about 190 temp, A/F was @ 12.5-13.2 or so. but as i increased my speed to closer to 70, temp rose to 210 or so, maybe a bit more, and the A/F went up to @14.2 . As i slowed down, and even at idle ,the temp came down to @ 180-190 again. - so is it because of running more lean? could it be timing/advance effecting this ? or do i need to adjust the MPS? cold idle it runs at 10.5-11, warms up and driving around town im around 12.5, hard acceleration in leans out some around 13.5, etc . - its at Bob Woodmans today, getting valves set/checked and timing(lost my timing mark on the impeller) so that will all be sorted out. today and taken out of the equation. oh, and the thermostat works, fins are in the right position , no blockage etc. - running brad penn oil. - |
76-914 |
Jul 16 2014, 07:09 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Whether you're running straight gasoline or E10, and using a wideband O2 meter that reads in A:F ratio, you want to see 13.5-12.9 on the gauge while accelerating or climbing, 12.8-12.5 at WOT, and 16-17 while cruising, going downhill or decelerating.
DRPHIL914 |
Jul 16 2014, 07:30 AM
Whether you're running straight gasoline or E10, and using a wideband O2 meter that reads in A:F ratio, you want to see 13.5-12.9 on the gauge while accelerating or climbing, 12.8-12.5 at WOT, and 16-17 while cruising, going downhill or decelerating. well i can tell you i am at about 14.5 at the highest when cruising(thats 2800rpm @ 70 mph, that really seems lean , 16-17 for a air cooled motor. after the timing and valves are set today, i will recheck it and see where its at, then may have to make some adjusmtnets to the mps . thats the only way i know of leaning out that cruising mixture. and normally i try to run 89 octane non-ethanol ,but lately its almost $4 a gallon here vs $3.25 for regular stuff. |
Lo-Fi Version | Time is now: 7th June 2024 - 09:03 AM |
