> Weber idf 44 leak!, Help!
Milkman7286
post Jul 1 2014, 07:37 AM
Hello all,
I've got a 71 4 banger with dual weber idf 44's on it and the driver's side front barrel has sprung a leak.
Here is a little detail before I go further into the leak:
The webers are about 6 years old and have about 7,000 miles on them. The car sat in storage for about 3 years but was started and driven every 6 months or so. For all I know this leak has been there all along and I never noticed, but I don't think that is the case.
The leak:
The carb is leaking gas down the front barrel on the drivers side. It appears to be coming from the progression / transition holes but it is hard to tell. The other thing I noticed is that the gasket just above the float bowl is very wet and the gasket between the carb/manifold is also a little wet. I have been dealing with this for about 2 weeks now and have read every possible thing I can find and none have solved this.
Here is what I have done so far:
-Float set at 10.5mm measuring with the gasket in place.
-Butterfly was loosened and repositioned in the bore.
-Needle and seat have been tested both with fuel and air and are good
-float is free in movement and does not hang up in the bowl
-float is still a float and does not sink
-idle circuit is free flowing and not clogged
-fuel pressure is 2.5
-float bowl gasket does not accidentally cover any holes or vents
Any ideas on this one? I feel like I have tried everything and for the life of me I can't figure it out. Last night I was watching the fuel puddle on top of the butterfly and it seemed like maybe it was coming from the seam at the float bowl gasket. Any reason why fuel would be coming from there?
As FYI:
This happens when the car is hot or cold, doesn't matter.
stugray
post Jul 16 2014, 08:22 AM
This is somewhat related since it sounds like the OP has had the top of his carbs on & off numerous times.
Anyone know where to get the weber IDF carb top gasket by itself?
I would like to have a couple spares but dont want to pay $30 each for the complete rebuild kits.
Milkman7286   Weber idf 44 leak!   Jul 1 2014, 07:37 AM
rhodyguy   can you see a dribble when the fuel pump is energi...   Jul 1 2014, 08:02 AM
Milkman7286   can you see a dribble when the fuel pump is energ...   Jul 1 2014, 08:51 AM
Mark Henry   If it's leaking from a press in plug in the bo...   Jul 1 2014, 09:16 AM
Milkman7286   If it's leaking from a press in plug in the b...   Jul 1 2014, 10:03 AM
Mark Henry   Leaking inside the carb is you have a fuel enrichm...   Jul 1 2014, 10:58 AM
Milkman7286   Leaking inside the carb is you have a fuel enrich...   Jul 1 2014, 11:12 AM
ThePaintedMan   :agree: With Mark. If one of the circuits is stuc...   Jul 1 2014, 11:39 AM
Milkman7286   :agree: With Mark. If one of the circuits is stu...   Jul 1 2014, 11:52 AM
ThePaintedMan   Mine does not have a lever, just a little block o...   Jul 1 2014, 12:27 PM
Racer Chris   Even without the entire enrichment assembly there ...   Jul 1 2014, 12:50 PM
Milkman7286   Even without the entire enrichment assembly there...   Jul 1 2014, 01:43 PM
Elliot Cannon   I have had 44idf's on my car for 10 years and ...   Jul 1 2014, 01:27 PM
Milkman7286   Barrel*....damn autocorrect   Jul 1 2014, 01:46 PM
ThePaintedMan   Sorry, I should have been more specific. The valve...   Jul 1 2014, 02:47 PM
Mark Henry   If leaking/spilling over the float bowl you more l...   Jul 1 2014, 03:22 PM
Milkman7286   Well, It wasn't the choke pieces, the plungers...   Jul 2 2014, 06:55 AM
72hardtop   Well, It wasn't the choke pieces, the plunger...   Jul 13 2014, 02:41 PM
Jake Raby   How new are these carbs? Do you have a pic of one ...   Jul 2 2014, 08:00 AM
Milkman7286   How new are these carbs? Do you have a pic of one...   Jul 2 2014, 09:07 AM
jmill   Would bad gaskets cause something like this? Ga...   Jul 2 2014, 10:24 AM
Milkman7286   Would bad gaskets cause something like this? G...   Jul 2 2014, 12:08 PM
ThePaintedMan   There are a lot of variables, not to mention good ...   Jul 2 2014, 10:55 AM
jmill   Do you have thick manifold to head spacers? Sound...   Jul 2 2014, 10:20 PM
Milkman7286   Do you have thick manifold to head spacers? Soun...   Jul 3 2014, 07:31 AM
jmill   The carb bubbling and gurgling after running sound...   Jul 3 2014, 10:36 AM
ThePaintedMan   The carb bubbling and gurgling after running soun...   Jul 3 2014, 12:14 PM
brant   did you test the floats in a cup of water when you...   Jul 3 2014, 12:13 PM
jmill   Ding, ding, ding. The plungers need to be in plac...   Jul 13 2014, 05:05 PM
Al Meredith   Are you sure they are Webers? About 6 years ago ...   Jul 14 2014, 01:35 PM
stugray   This might be a long shot, but dont carbs need a v...   Jul 14 2014, 06:01 PM
Milkman7286   Ok guys I finally got around to the carbs again an...   Jul 15 2014, 11:19 AM
jmill   Clean up around the O ring seat and possibly get s...   Jul 15 2014, 11:33 AM
Milkman7286   Clean up around the O ring seat and possibly get ...   Jul 15 2014, 11:38 AM
rhodyguy   the screws you're talking about, idle air mixt...   Jul 15 2014, 12:03 PM
Milkman7286   the screws you're talking about, idle air mix...   Jul 15 2014, 12:09 PM
rhodyguy   correct. one less thing to worry about.   Jul 15 2014, 03:56 PM
Milkman7286   All: Just fired the old girl up with everything m...   Jul 15 2014, 04:50 PM
jmill   You installed the spacers too? This fuel you see ...   Jul 15 2014, 05:39 PM
Milkman7286   You installed the spacers too? This fuel you see...   Jul 15 2014, 07:54 PM
72hardtop   What type if any fuel pressure regulator are you u...   Jul 15 2014, 06:15 PM
Milkman7286   What type if any fuel pressure regulator are you ...   Jul 15 2014, 08:01 PM
jmill   Theres only a couple of reasons to have fuel leaki...   Jul 15 2014, 08:28 PM
Milkman7286   Theres only a couple of reasons to have fuel leak...   Jul 16 2014, 07:07 AM
stugray   That is what I meant earlier. It sounds like you...   Jul 15 2014, 09:27 PM
Milkman7286   That is what I meant earlier. It sounds like yo...   Jul 16 2014, 07:02 AM
jmill   The float bowl vent (which is a huge slotted hole)...   Jul 15 2014, 10:26 PM
Milkman7286   The float bowl vent (which is a huge slotted hole...   Jul 16 2014, 07:00 AM
jmill   What keeps the fuel from dripping on its own on t...   Jul 16 2014, 08:06 AM
Milkman7286   What keeps the fuel from dripping on its own on ...   Jul 16 2014, 08:13 AM
rhodyguy   when the engine is running does the engine respond...   Jul 16 2014, 08:18 AM
Milkman7286   when the engine is running does the engine respon...   Jul 16 2014, 08:36 AM
stugray   This is somewhat related since it sounds like the ...   Jul 16 2014, 08:22 AM
jmill   Don't stick ANYTHING into the passageways/por...   Jul 16 2014, 09:06 AM
Milkman7286   Don't stick ANYTHING into the passageways/po...   Jul 16 2014, 09:48 AM
jmill   There's 3 holes that need to be clear. I made...   Jul 16 2014, 10:29 AM
Milkman7286   Update: Last night I put in a new seat and needle ...   Jul 17 2014, 07:00 AM
ThePaintedMan   You mentioned in your original post that you ...   Jul 17 2014, 07:32 AM
Milkman7286   You mentioned in your original post that you ...   Jul 17 2014, 11:56 AM
jmill   What I'm now wondering is: if the lowest prog...   Jul 17 2014, 12:11 PM
rhodyguy   yep. the 4 progression holes are effectively block...   Jul 17 2014, 12:11 PM
Milkman7286   Either way I'll look at the throttle plate and...   Jul 17 2014, 12:48 PM
stugray   I am not as familiar with the 44 options. Do you...   Jul 17 2014, 12:54 PM
jmill   Again, with the engine off, no fuel should leak ou...   Jul 17 2014, 02:22 PM
Milkman7286   Again, with the engine off, no fuel should leak o...   Jul 18 2014, 10:53 AM
- Lo-Fi Version Time is now: 15th July 2025 - 06:34 AM
